greddy type s bov extra inlet?
Old Feb 20, 2009 | 09:19 AM
sonne_side's Avatar
Default greddy type s bov extra inlet?
i have an ls-turbo and was wondering where the extra inlet goes
Old Feb 20, 2009 | 05:48 PM
Unknown Racing's Avatar
Default Re: greddy type s bov extra inlet?
you can leave it off I have mine reading atmospheric. I have a vacuum line hooked up the the one in the middle and the one below it I have open. ive heard some people hook another vacuum line up to that if your valve is flutter but that usually can be fixed by loosening or tightening it.
Old Feb 20, 2009 | 09:54 PM
HiProfile's Avatar
Now if you had searched.... j/k
THe lower port connects the lower half of the diaphragm to boost (pre-throttle body). When you let off throttle, vac is introduced above, and boost remains below. The valve is opened faster, and with less boost. This helps with flutter and momentary compressor surge, but at the expense of holding higher boost. It should be a non-issue, since originally Greddy recommended to use the Type-R BOV above ~15psi anyways.
It can also help with keeping it closed at idle ever so slightly, since the FMIC's pressure drop can create an ever-so-slight vacuum in the charge pipes, which holds the valve closed a fraction farther. Enough to theorize about, but not enough for practical use...
akdrag
Sep 2, 2009 04:15 AM
Crasian
May 10, 2006 11:14 AM
hotimportcrx
Jun 9, 2005 10:03 AM
TheIntegraGuy
Nov 18, 2002 08:35 AM
revhrdls
Oct 13, 2001 04:29 PM
