help no spark
Old Feb 20, 2009 | 06:15 AM
iheartmyctr's Avatar
Default help no spark
so i have 0bd2 ls motor with obd1 alt, and brand new 0bd1 dizzy cap and rotor, new wires, plugs and battery. has obd1 vtec harnes with obd1 to obd2 jumper to a obd2 ls ecu. dizzy getting power but not sending spark as was the old one. it will crank just not turn over. grounds are good and fuse is good. fuel pump kicks on and primes and i have fuel so its just the spark thats getting me any help would be appreciated thanks guys
Old Feb 20, 2009 | 10:09 AM
randomnineh2b's Avatar
Default Re: help no spark
replace the internal coil in the dizzy
Old Feb 23, 2009 | 02:14 PM
i replaced the whole dizzy and changed the ecu? also the cfp is not hooked up so is that a possible reason y? cant i wire the ckp to ecu if thats the case
Old Feb 23, 2009 | 05:03 PM
mouab18c1's Avatar
did it just not start all of a sudden?
Old Feb 24, 2009 | 01:21 PM
no took it out of a running car put it in this car but wondering since the crank fluction sensor is not pluged up if that would cause no spark?
Old Feb 25, 2009 | 07:07 AM
mouab18c1's Avatar
no the CKF sensor has nothing to do with spark...check for blown fuses..bad spark plug wires...
Old Feb 25, 2009 | 07:36 PM
i will check over on the fuses, i allready replaced batt, dizzy, cap, rotor, plugs, wires, ecu, so kinda at a loss
Old Feb 26, 2009 | 06:57 AM
mouab18c1's Avatar
did you check your main relay?
Old Feb 26, 2009 | 07:59 AM
fcm's Avatar
fcm
Old Fart
Do you have 12V+ at the distributor assembly when ign. switch is in run or start?94
PS, Black/yellow lead I think.
Old Feb 26, 2009 | 04:36 PM
yes i have allready checked that and thats why i am stuck dizzy gets power just not sending spark so maybe tonight i will check the fuses and relays if i have time
beamer
May 21, 2016 07:56 AM
beamer
May 19, 2016 06:11 PM
hulsey
19
Mar 6, 2013 07:54 PM
Bambooseven
Jun 29, 2011 01:01 PM
Emshhh
29
Jul 11, 2007 06:13 PM
