vtec hook!
Old Feb 19, 2009 | 09:02 PM
ek coupe's Avatar
Default vtec hook!
whats the easiest cheapiest way to hook up vtec without buying a ecu? i want to hook it up for like a day or so then ill buy a ecu! ive people hooking it up to there tach
Old Feb 19, 2009 | 09:11 PM
I AM WEASEL's Avatar
Default Re: vtec hook!
What chassis, motor and wiring harness would be beneficial to better help us in answering our question.
Old Feb 19, 2009 | 09:15 PM
ek coupe's Avatar
z6 head zc bottom end obd2 wiring harness! i just want to have it hook up for less then a day! until i can find a ecu that will work
Old Feb 19, 2009 | 09:27 PM
ek coupe's Avatar
Old Feb 19, 2009 | 09:34 PM
ALLxMOTOR EG's Avatar
Vietnamese!
Just wait till you get the ECU
Old Feb 19, 2009 | 09:40 PM
ek coupe's Avatar
i hate waiting thats the thing
Old Feb 19, 2009 | 09:42 PM
ek coupe's Avatar
and i dont know how long it will be until i can get a ecu
Old Feb 19, 2009 | 09:44 PM
yoshi-ua's Avatar
do you have a vtec ecu right now?
Old Feb 19, 2009 | 09:47 PM
ek coupe's Avatar
i had one but it didnt work
Old Feb 19, 2009 | 10:07 PM
ek coupe's Avatar
i can probably get one for the $30 but i have to drive like 150 to 200 miles just to get it
Old Feb 19, 2009 | 11:55 PM
trustdestruction's Avatar
you really should get a P28 ECU and an OBD1/OBD2 ECU conversion wire harness
wiring info
http://hondacivicforum.com/forum/showthread.php?t=73241
for OBD1 (which is what you'll be referencing for ECU pinouts if you get a conversion harness and a P28) on a D-series, pay attention to pins A4 and D6
Old Feb 20, 2009 | 07:20 PM
ek coupe's Avatar
i dont really get what the p28 gonna do that the p2p cant do! there with vtec ecu! the p28 out of the si and the p2p out of the ex! just think about i wouldnt have to get a jumper harness, there all vtec ecus
Old Feb 20, 2009 | 08:00 PM
well the P28 is made for the D16Z6 engine, so it would possibly run a tiny bit better. The Z6 and Y8 have slightly different cams. It's negligible, but OBD1 is better anyways. Less stuff to worry about during the swap, less stuff that can throw a code. Plus if you ever plan on going turbo, you can chip the P28. You can't chip an OBD2 ECU.
Old Feb 21, 2009 | 07:54 PM
ek coupe's Avatar
i have heard with the p28 if you dont have a knock sensor you dont have to install one with the p28 is that true?
Old Feb 21, 2009 | 08:36 PM
yes, that is true. another reason why a P28 is easier to use.
Old Feb 21, 2009 | 09:11 PM
ek coupe's Avatar
and i wont be throwing codes all day long
Old Feb 21, 2009 | 09:22 PM
ek coupe's Avatar
so all i have to do is get a conversion harness and thats it?
Old Feb 21, 2009 | 09:23 PM
yes
Old Feb 21, 2009 | 10:26 PM
ek coupe's Avatar
i heard getting a new fuel rail and fuel injectors is a good idea too
Old Feb 21, 2009 | 10:32 PM
ek coupe's Avatar
what kind of fuel rail and fuel injectors would you recommend?
Old Feb 21, 2009 | 11:50 PM
jdm602's Avatar
by the way your talking it sounds like you dont know what your getting into. to have vtec you need a vtec ecu. you cant simply hook it up for a little bit without one. and you cant add vtec with a tach.
fuel rail = no. stocks fine. supports huge amounts of power.
injectors = depends on setup (all motor/turbo/type of gas)
Old Feb 22, 2009 | 12:42 AM
sanegb16's Avatar
borrow your friends ecu if you want it for "a day"
idk why you would waste your time
get an obd2-obd1 jumper harness and run a p28
and get rid of all your check engine lights or no vtec anyways
Old Feb 22, 2009 | 05:50 AM
blackvtecteg's Avatar
New User
If you really wanna just hook it up run a wire to a power source, like your radio or fuse box. That'll make the vtec come on but the ecu you have isn't going to let you take advantage of vtec. You'll most likely hear it not feel it. And it will be on all the time unless you unplug it. Not to mention you'll probably throw codes. Just get a p28 and conversion harness like stated. You wont mess s**t up that way.
Old Feb 22, 2009 | 09:26 AM
joelmatt89's Avatar
when vtec engages what all does the ecu change, is it just the cam lobes or does it add more fuel etc. Can someone please help me out here i am sure mine isn't working right but i know the lobes are engaging it just doesn't feel or sound like it is engaging. It's not that I really care about the sound but I used to be able to tell that it was engaging by the sound and the power now i don't have either. So what other things does the ecu change. For some reason i have found that it seems like nobody on here really knows what all it does, or i am just finding the wrong people. Trust destruction im gonna call you out on this one you know your stuff and i see you have been posting on this thread ... HELP ME OUT man i am in need!
Old Feb 22, 2009 | 09:30 AM
Andr3w's Avatar
lol i had a light switch to engage my vtec when i had did my first swap years ago..
Would get into a race.. and i had my buddy beside me and id scream go when to engage and he would turn it off when i would shift...aw good times lol
