Weird idle help
Old Feb 19, 2009 | 04:25 PM
shake-zula's Avatar
Default Weird idle help
ok here goes....couple months ago i purchased a b20b installed it no problem along with a obd1 ls ecu with the jumper harness...back then when i first started the car, the idle would bounce at 1000 to 1500 then after it warmed it would idle fine but now recently i guess cause of the cooler weather, right when i start the car the rpms would jump to 3000rpm for about a minute or 2 and bounce at 1500rpm when warm.... i tried looking for a vacuum leak with no luck....i need some suggestion where to start looking, its driving me crazy...because of school now i dont have all that much time....thanks for the help
Old Feb 19, 2009 | 04:46 PM
shake-zula's Avatar
Default Re: Weird idle help
no check engine light too.....
Old Feb 19, 2009 | 08:53 PM
shake-zula's Avatar
also everytime i go to shift and step on the clutch the rpms jump a little higher instead of dropping....
Old Feb 21, 2009 | 06:22 PM
shake-zula's Avatar
bump
d0wnShiFt
Aug 5, 2018 01:32 PM
DO/\/\O
14
May 9, 2011 05:56 PM
93c1sol
Apr 23, 2006 08:31 PM
EK Josh
29
Apr 11, 2005 11:05 AM
