cleaned the b18 block today...bored?
Alright, im on vaca and me and my buddy cleaned the block today....one thing down on the list, it came out pretty good we didnt spend much time on the back part ill finish it when it goes in the car.
this thing had an inch of grease on it b4 this. i used gas and tooth brushes.
Your supposed to take the carbon off the top of the pistons?
yeah the plate got hit with some chunks off my gsr trans. not good, but still performs fine
I'll finish it in spring, but there was so much gunk on it i wish i took a pic of it before..
I think im powdercoating my fat 5's white, calipers black, and vc white or black im leaning white because 50% of civics are black, and id like to powdercoat the alt. bracket and some more little stuff black so it doesnt look crappy.
only thing is i'm not sure how white rims will look on a red car?
Who cares if the degreaser hits the cylinder walls? You will be cleaning the rings while your at it also.. Once its all cleaned use brakeclean to get around the piston, and then use compressed air until no more carbon is coming out from around them, then lower the piston, and pour in some oil and rock the crank back and forth a few times to re-coat the rings and walls, then let it sit. I've done this on several motors and all it has done is good.
I'd change the oil before running the motor again afterwards also.
mynameizstitch
Jul 8, 2009 08:29 AM
mynameizstitch
Jul 7, 2009 07:13 PM
ImportReview
Aug 8, 2002 08:14 PM
