civic won't start. please help
Old Feb 19, 2009 | 03:40 PM
turbotypeR@SPEC's Avatar
25 Year Member
Default civic won't start. please help
I am working on a 92 civic cx at work that won't run. I need to get it running first thing in the morning since I am leaving out of town.
I have installed new cap, rotor, wires, plugs. I changed the distributor, coil and tried two ignitors. Compression test was 170,190,170,190. The timing of the cam and crank are correct. the firing order on the wires are right. and the distributor is pointing at number 1 when at TDC. The plugs are firing, but not the injectors. It is the damndest thing I have ever seen. I have done every check in the service manual and still nothing. The fuel pump is running and it has 43psi fuel pressure. I even plugged up my Hondata S300 and downloaded a stock D16 calibration. The only thin I have found to be strange is that the log on the S300 always shows -4deg timing. even while cranking and if advance or retard the distributor. Please give me any opinions on what it could be. Like I said, I am leaving out of town tommorow and need it to be running before I can leave. HELP!
Old Feb 19, 2009 | 04:42 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: civic won't start. please help
do you have 12v on the yellow and blacks on the injectors? stupid question is the dead plug installed?
Old Feb 19, 2009 | 05:01 PM
25 Year Member
Yes. The injectors have ignition. I forgot to mention that. What is the dead plug?
Old Feb 20, 2009 | 02:58 AM
25 Year Member
nobody?
Old Feb 20, 2009 | 06:09 AM
fcm's Avatar
fcm
Old Fart
If the injectors have power then they are not getting the ground signal from the ECU/ECM. 94
Old Feb 20, 2009 | 07:30 AM
Mr. Badwrench
yup.
the dead plug os on the drivers side harness. the plug that looks like it has nothing in it. if you have 12v at the injectors, its plugged in.
damn danny there isnt much left. if you have 12v at the injectors, check continuity from all the injectors back to the ecu.
i cant see 2 ecu's having bad drivers.
ground good on the tstat housing?
Old Feb 20, 2009 | 08:23 AM
25 Year Member
yeah, it has 12v at the injectors. i even took the rail out and held the injectors against the valve cover and the are firing and releasing fuel.the plugs are firing and the crank and cam are timed right and the rotor points at #1 when the crank and cam are at tdc. i am freaking lost
Old Feb 20, 2009 | 10:17 AM
philafelman's Avatar
is it possible you have the plug wires installed in the wrong positions on the dizzy?
Old Feb 20, 2009 | 12:16 PM
25 Year Member
nope. at tdc it points at #1 and the firing order is1-3-4-2
Old Feb 20, 2009 | 12:59 PM
DonF's Avatar
The only thing i can think of is to put an olm meter on the grond side of the injectors, turn the car over and see if the ground fluctiates, if not you have an open ground to the injectors.
Old Feb 21, 2009 | 03:48 AM
25 Year Member
the injectors are firing. i took them out and held them in the rail and watched them spray fuel
Old Feb 21, 2009 | 09:49 AM
fcm's Avatar
fcm
Old Fart
Wait, I though you said... " The plugs are firing, but not the injectors"
Hmmmmm?
If you have spark and you have fuel and engine will not fire it can only be timing.
Yes firing order is 1342 and you are using the cylinder on the right, [opposite end of block from the distributor] as the #1 cylinder, right?94
Old Feb 23, 2009 | 04:32 PM
25 Year Member
yeah, originally i thought the injector were not firing, but i did pull them out and watch them fire. and yes the only thing i can come up with is timing or for some reason the plugs are not getting a ground when in the head, but i know they are. i just got back in town and get to work on it some more tommorow. hopefully i can come up with something
Old Feb 24, 2009 | 05:33 AM
ohsnapzafingcu's Avatar
I serve phở for my babies
are the vacuum readings normal? anything clogging the exhaust or intake?
Old Feb 28, 2009 | 04:25 PM
25 Year Member
i put a new distributor on and it runs now. strange, the timing of one of the magnetic sensors had to be off or something
ToTriggerHappy
Jun 8, 2010 07:52 AM
Sturg
Oct 27, 2009 12:04 AM
cardioid
Mar 13, 2009 09:04 PM
gottats25
Jun 29, 2005 05:07 PM
