replacing belts
Old Feb 19, 2009 | 02:06 PM
noz's Avatar
noz
Default replacing belts
could someone tell me how to R&R AC, Power Steering, and alternator belts
this is my first attempt so any pointer would help, thanks in advance
oops i forgot to mention is my cars is a 92 DA integra very tight space around the belts
Old Feb 19, 2009 | 04:46 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: replacing belts
helps to know what we are working on.
if it is a civic or teg,
12mm wrench take the ps pump off move it out of the way, i think the ac tensioner is a 12mm or 14mm, loosen up the weird looking nut, loosen the 12mm jam nut and loosen the adjuster. you will need to remove the engine tq strut 14mm bolts to remove this belt.
12mm bolt on the alternator and use a prybar to pry the alt out of the way.
install in reverse order.
cb7pr
Texas -OK -LA (Sales)
30
Apr 8, 2010 06:25 AM
cb7pr
Apr 8, 2010 05:36 AM
em1blk2000
Jan 9, 2009 08:08 AM
StreetRac3r
Jan 29, 2008 07:56 AM
