Blinkers stopped working
Old Feb 19, 2009 | 11:36 AM
blink384's Avatar
Icon2 Blinkers stopped working
Basically I bought a 95 integra with a jdm frontend because I had one about 3 years ago and sold it and missed it like hell. SO i bought a new one but it had Uper gay tan interior. I switched out the dash board and found some type r seats and all the goodies to Black. WHen I did that my blinkers stopped working. Everything else is working fine. THe blinkers start flashing when the Hazard switch is pushed. That eliminates the bulbs, I also checked all the fuses (all good).
Any body have any suggestions?
Old Feb 19, 2009 | 11:57 AM
blink384's Avatar
Icon6 Re: Blinkers stopped working
Really wanna try to fix this today. Anybody?
Old Feb 19, 2009 | 01:34 PM
imsickofrice's Avatar
Default Re: Blinkers stopped working
when this happened to me... i doublechecked all the fuses, and the fuse for my rear tail light was somehow connected to my turn signals.. i replaced that fuse and it started working again.. take 3 minutes of your time and double check ALL the fuses..
Old Feb 19, 2009 | 06:13 PM
blink384's Avatar
I checked all the fuses, but i will double check them right now.
Anybody else have any suggestions?
Old Feb 20, 2009 | 10:19 AM
blink384's Avatar
Post Re: Blinkers stopped working
I checked all the fuses and still no luck! I went to pep-boys and saw they had BLinker-Relays...does anyone know where or if Integras have these? Possibly that went out?
Old Feb 20, 2009 | 02:17 PM
stevn's Avatar
once i had a pinched wire somewhere behind my dash after i re-installed it and it caused the same problem....
Old Feb 20, 2009 | 02:52 PM
milo-gsr's Avatar
recheck your wires again. Maybe you forgot to plug some wire in when you swap the dash board.
Old Feb 20, 2009 | 05:03 PM
banks358's Avatar
u get water in the lights?
Old Feb 20, 2009 | 09:36 PM
blink384's Avatar
No water in the lights, double checked all the harnesses. I guess it could be a pinched wire, but I pulled off the dash a couple inches looked for clearance and everything looked fine. Can't figure it out....anyone know about a blinker relay? If they have them in hondas?
Old Feb 21, 2009 | 08:52 AM
94_Teggy's Avatar
my blinkers stopped working yesterday when i touch the blinkers wires together and i think the relay went cause all the fuses are fine..can u get the relay at an autopart store and where is it located?
Old Feb 21, 2009 | 02:03 PM
steveharrmr23's Avatar
have you checked your blinker relay
Old Feb 21, 2009 | 06:50 PM
blink384's Avatar
Where is the blinker relay? Didn't know where its located. Would my e-flashers still work if the relay went out?
Heart4Tuners
Jul 24, 2011 11:33 AM
barnie
Sep 7, 2009 07:45 PM
trick_db
Sep 15, 2007 07:31 AM
d16z6hondacrx
Oct 17, 2005 04:36 PM
DropSquadCivic
Sep 11, 2003 10:00 PM
