b16a running ritch..
Old Feb 19, 2009 | 09:19 AM
EF-8SiR's Avatar
Default b16a running ritch..
Old Feb 19, 2009 | 11:58 AM
EF-8SiR's Avatar
Default Re: b16a running ritch..
Old Feb 19, 2009 | 04:29 PM
EF-8SiR's Avatar
ex.
cracked injecectors, broken fuel pressure regulator, tps not times, o2 sensors, ecu, intake clogged and SO ON.
I'm in need of some re-assurance here, any help with the most common problems that would make my car run this rich?
Thanks!
Old Feb 19, 2009 | 09:17 PM
89s1's Avatar
injector stuck open maybe?
If so, you can get the injectors balanced to fix it.
Old Feb 19, 2009 | 09:19 PM
FOMULA91's Avatar
ur using 2 O2 sensor or one? Any code flashing?
Old Feb 19, 2009 | 09:22 PM
SIred91's Avatar
Rainman
Originally Posted by EF-8SiR
ex.
Thanks!
This is why you are screwed. FIX IT. Or are you asking if those could be the issue?
Old Feb 19, 2009 | 11:03 PM
EF-8SiR's Avatar
Old Feb 20, 2009 | 04:43 AM
Furyof4's Avatar
I'm not throwing any CEL's but it seems that my cluster always has the cel code warning light on.
Any help is appreciated,
thanks,
Do you know how to check codes? If the CEL is on, you either have codes or there is an ecu problem.
Old Feb 20, 2009 | 11:02 AM
ef_junky's Avatar
well you should have the two o2 sensors and there probably in the wrong places try swapping them at the ecu heres the pins it fixed my problem of running rich you should be switching c8 and c16
Old Feb 20, 2009 | 12:28 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
This is how they should be wired looking at the exhaust:
You can swap the the sensors around in the exhaust like so:
But sometimes the wires are a little short..
Old Feb 20, 2009 | 04:35 PM
EF-8SiR's Avatar
Old Feb 21, 2009 | 12:30 PM
EF-8SiR's Avatar
any help HT?
Old Feb 13, 2011 | 07:16 PM
JDM BORI's Avatar
My B16 is doing the same thing but worse. I can't figure out what the problem is. It's running so ritch it sounds like its camming. I've gone from changing out the O2 sensor to changing out my map sensor, ecu, wiring harness, injectors...idk what is wrong with the damn thing. I've checked the timing several times & its in perfect timing. I NEED HELP!
typeRef
17
Jun 3, 2013 05:35 AM
bigizsosexy
Jun 27, 2008 09:43 PM
decay_flouride
Jun 4, 2007 11:32 PM
dohctor_B
May 4, 2006 06:32 AM
silverCRXTC
Jun 3, 2003 06:50 PM
