fuel problum
my car blew a relay and now its dumping to much fuel the relay was replased that is when the problum stared i have changed the injecters fuel regulater computer o2 sensor and it is still doing it i cant think of anything else to fix any one have any ideas
From: Howcome we park on driveways, and drive on parkways?
wait, first SPELL CHECK IS A GREAT TOOL...use it, it will help people in reading your message.
ok..now...to the problem...
- What vehicle?
- What motor?
- Which relay blew?
- How did you know the relay blew?
- How did you know it was dumping too much fuel?
- Why change the computer? What computer were you using and which one now?
- o2 sensor? What other issues led you to decide to change o2 sensor.
- What vehicle?
- What motor?
- Which relay blew?
Thanks! I have a 1991 Honda civic hatch back with a 95 del sol s motor. First off the IG relay blew my friend did not have one so he jumped it with a piece of wire and I am not the one who changed the relay my friend did it when he had the car. I can smell the gas in the exhaust when the car is running it keeps fouling the plugs so it won’t start unless i clean them off they are black when i pull them out not brown like they need to be. My friend thought the something got messed up in the computer. I thought the o2 sensor might be bad so i changed it.
WOW....dude...you NEED a relay on your ignition...otherwise i believe your fuel pump is CONSTANTLY RUNNING if he jumped the relay ..wow, this is why you constantly have to clean the plugs just to start it....and then you can smell the gas in your exhaust...
get on that man. ride a bike to autozone. You have to ride a bike on this one so you remember to never let something like this happen again as you pedal uphill both ways. tell them you need a relay for your ignition for your '91 civic. Good luck
the relay has already been replaced. that's not the problem. look dude dont talk to me like im a dumb *** im not im just trying to fix my car and i dont know what else to check
acaliguy
Feb 28, 2013 11:44 PM
