How to check coolant temp sensor?
Old Aug 9, 2002 | 06:57 PM
TenaciousC's Avatar
Default How to check coolant temp sensor?
I have no helms manual, i'm trying to find out if there is anyway to check the coolant temp sensor. thanks
Old Aug 9, 2002 | 07:01 PM
minime's Avatar
Default Re: How to check coolant temp sensor? (TenaciousC)
the fan sensor or the guage?
Old Aug 9, 2002 | 07:06 PM
TenaciousC's Avatar
Default Re: How to check coolant temp sensor? (minime)
the sensor that reads the coolant temp
Old Aug 9, 2002 | 07:40 PM
minime's Avatar
there is a one wire connector on the bottom of the head that runs the guage. a two wire connector on the t stat housing that runs the fans.
Old Aug 11, 2002 | 12:04 AM
tinkerbell's Avatar
there are two - one that tells the ECU what temp(ECT) and the other for teh cluster gauge.
to test the ECT one, it should read about 1000 ohms at 100'F
HTH,
t..
Old Aug 11, 2002 | 05:16 AM
EE_Chris's Avatar
Default Re: How to check coolant temp sensor? (tinkerbell)
Try THIS.
[Modified by EE_Chris, 2:18 PM 8/11/2002]
Old Aug 11, 2002 | 06:19 AM
BigMoose's Avatar
Default Re: How to check coolant temp sensor? (EE_Chris)
Now that you have the resistance specifications from Chris, if you need to check the calibration, I put them in a pan of water with a thermometer on the stove. gradually heat and compare resistance with your thermometer of choice. I use a refrigeration dial type thermometer.
Regards,
BigMoose
busyychild
May 6, 2008 11:09 AM
vtecaccord 1
Dec 7, 2004 05:59 AM
JoshM
Jun 2, 2002 06:11 PM
