Lowerig/dropping a civic
Old Feb 19, 2009 | 04:27 AM
671islander's Avatar
Default Lowerig/dropping a civic
i need some help,im new to all this lowering ride thing. i own a 97 civic sedan i wanna lower it. im rolling on ground control coilover. i recently purchase an spc camber kit the front is 1.5-+1.5 and the rear is -2.0-+5.0. my question is how low can i lower my car, without making my car camber? also if anyone has any pic of how low i can lower my car within those range of my camber would really help.
Old Feb 19, 2009 | 02:29 PM
Default Re: Lowerig/dropping a civic
bump bump bump
Old Feb 19, 2009 | 06:17 PM
TunerN00b's Avatar
Making the car camber? Lmfao.
And you don't. You lower the car, and enjoy the fact that the increase in negative camber allows better cornering.
Do some research in the suspension forum. This has been covered countless times.
Old Feb 20, 2009 | 05:27 PM
KuEy's Avatar
LOL. well, it depends on what wheels you have and all as well. just take your time dropping it a bit at a time to see when it will start rubbing. and i would recommend you rollin g your fenders if you plan to slam your car.
Old Feb 20, 2009 | 10:38 PM
aight got it problem all solve i just took it to a local auto shop.
Old Feb 22, 2009 | 10:37 PM
NAHHHHH's Avatar
if you try to slam your car your def going to end up with camber i have front and rear camber kits and also have polished slips and im lowered a tad bit and i have no camber at all
Old Feb 23, 2009 | 04:01 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
And your car also handles worse than if you kept the stock components and used the stock camber curve to your advantage.
knaira112387
Honda Civic (2006 - 2015)
11
May 1, 2009 08:07 PM
KiNG $h!t
Suspension & Brakes
Mar 7, 2005 10:52 AM
Resident Evo
Nov 11, 2004 09:54 PM
RedHB..D15B
Apr 2, 2004 03:08 PM
imported204
Sep 1, 2002 07:19 AM
