Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Removin Rad support
Old Feb 19, 2009 | 12:25 AM
RedEG8's Avatar
Default Removin Rad support
I recently got in to a rear ender, now I need help takin of the tig welds...what are some easier options?? ive been told to drill 1/4 inch thru the welds then use a air chizzle and it should come off like butter.
btw how much do brand new ones go for? or ones from the junkyard??
thanks
Old Feb 19, 2009 | 07:38 AM
toyomatt84's Avatar
Sanji
Default Re: Removin Rad support
I doubt those are TIG welds that need to be removed. I would say they're Spot welds that you have to drill out and then you can use a MIG welder to replace them. Check the FAQ thread for parts listings for both OEM and Salvage Yard.
Old Feb 19, 2009 | 10:47 AM
unevolved's Avatar
Be careful trying to use a chisel to get them loose, that's a great way to tear the structure underneath if you're not careful. I've done it, it's easier than you'd think.
Old Feb 19, 2009 | 11:47 AM
DazeMS's Avatar
ebay.. thats how I got mine.. 70$ shipped for a new one.. the metal is pretty weak you should have no problems drilling them out, which is what I would do...
Old Feb 19, 2009 | 03:25 PM
Targa250R's Avatar
be professional
Spot weld drill bit.
Old Feb 20, 2009 | 12:08 AM
RedEG8's Avatar
thanks for the tips!
how long did this take you guys?
and im guessin you took it to a shop to get it MIG welded?
Old Feb 20, 2009 | 06:08 AM
Pachanga02's Avatar
Same thing happened to me. Its pretty easy to take it off, I drilled it first then took the grinder to even it out and then borrowed my friends mig welder and did it myself. Took about an hour to remove and put on.gl with yours
Steven Taylor
Audio / Security / Video
Aug 16, 2016 02:11 PM
weiRtech
Welding / Fabrication
17
May 20, 2008 01:42 PM
Dekorum
May 1, 2008 06:05 PM
skeletal29
Nov 6, 2007 08:21 PM
PushinRedline
Apr 20, 2004 01:31 PM
