Performance General Performance oriented Parts (Ex: Camshafts, Electronics, Air Intakes, Exhausts, complete engines)
H2B Kits by Evolution Industries EG, DC, EK, and now EF! TWIN DISC Compatible!!!
Old Feb 18, 2009 | 11:23 PM
ExospeedAMcrx's Avatar
Default Evolution H2B Kits EG, DC, EK, and now EF! TWIN DISC Compatible!!!
Evolution H2B Kits for your EG/DC, EK and EF Chassis
Now available with Tilton Twin Disc setups!
From the #1 Evolution H2B source. Buy from an Authorized Evolution Dealer
EK Kit shown
EG/DC 92-95 Civic and 94-00 Integra
- H2B Kit $1385 with complete engine mount kit
EK 96-00 Civic
- H2B Kit $1585 with complete engine mount kit
Parts included:
H2B Adapter Plate
SFI Approved Aluminum Forged Flywheel & Locking Plate
Pillow Block with Bearing
Slave Cylinder Extension Block
PCV Valve Extension (mounts on Valve Cover)
Block Clearance Template
Assorted Necessary Bolts
EG/DC: 3 CNC Billet Motor Mounts with Engine Side Mount
EK: 3 CNC Billet Motor Mounts with 2 Billet Mount Brackets
EF 88-91 Civic/CRX
- H2B Kit $1575.00 with complete mount kit
Parts included:
H2B Adapter Plate
Alternator relocator bracket
EF: CNC Billet Motor Mounts and Brackets
Evolution H22 Pulley
Note: Requires Balance shaft removal for proper clearance of frame. No modifications required on chassis if balance shaft is eliminated.
Kit is for use with Cable B-Series transmission.
Options:
Tilton Twin Disc Clutch setup with Evolution H2B Tilton Twin Disc Flywheel
Add to your H2B Kit order: $1150
Upgrade your current Evo H2B to Twin Disc $1545
(Includes Evolution H2B Twin Disc Flywheel and Tilton Clutch Assembly)
Frequently asked questions:
1. What other parts do I need to make this H2B Swap work?
The H2B swap is just like any other engine swap required to do to the chassis you want to put it in. If putting an OBD1 H22 swap over, you would need to convert to the proper wiring to make that H22 setup work in that car.
Axles and halfshaft are B-series.
B-series clutch to match the transmission you are using(cable or hydro)
B-series shift linkage
H22 header modified at the collector
and of course the H-series longblock and a B-series transmission
2. How will the ground clearance be with the Evolution H2B kit?
The Evolution H2B kit was designed to have good clearance for an average street car. Keep in mind that everyone has their own desired ride height and obviously, the lower the car, the less ground clearance there will be.
3. How is the hood clearance with the Evolution H2B?
The EG, DC, and EK chassis will clear the hood with minimal modifications. It should be able to clear especially with the PCV relocator bracket. The EF H2B is not so fortunate due to the limited ground clearance so hood clearance was sacrificed.
Exospeed Racing Designs is currently in the process of manufacturing a hood to clear this H2B setup for the EF chassis.
Evolution H2B Kit in EF chassis
Evolution H2B kit in EK chassis
Evolution PCV Relocator Bracket: can also be sold separately $45
Old Feb 20, 2009 | 03:13 PM
Default Re: H2B Kits by Evolution Industries EG, DC, EK, and now EF! TWIN DISC Compatible!!!
EF H2B Kit: Hottest product of the year!
Call us at 661-775-1963
PM here on HT
email us at sales@exospeed.com
Old Feb 21, 2009 | 07:21 AM
NOW AVAILABLE WITH TWIN DISC OPTION!!! for you high HP guys out there.
PM here on HT
Old Feb 23, 2009 | 09:52 AM
Tech and Sales Questions, feel free to contact us.
PM here on HT
Old Feb 23, 2009 | 09:53 PM
JustOneOrTwoPosts's Avatar
Icon7 Re: H2B Kits by Evolution Industries EG, DC, EK, and now EF! TWIN DISC Compatible!!!
bump for exospeed
Old Feb 24, 2009 | 10:42 AM
PM here on HT
email us at
sales@exospeed.com
Old Feb 25, 2009 | 08:49 AM
PM here on HT
Old Feb 27, 2009 | 08:46 AM
PM here on HT
email us at
sales@exospeed.com
Old Mar 4, 2009 | 08:09 PM
Call us: 661-775-1963 M-F 10am-5:30PM PST
PM here on HT: exospeedAMcrx
email us: sales@exospeed.com
Contact us for any tech questions. We actually use what we sell. We're racers just like you!
Old Mar 4, 2009 | 11:29 PM
Boosteddb8's Avatar
bump! Will there be a hydro version for the ef any time soon? I got 2 crx's in need for them!!! Also how about solid mounts or solid mount inserts?
Old Mar 4, 2009 | 11:43 PM
The CRX/EF kits utilize a Hasport made H-ser mount kit specific for the Evolution H2B setup. We havent tried yet, but we are planning to use the Hasport Solid inserts.
As of right now, the CRX/EF Evolution H2B kits are made for the Cable transmission.
I dont know if there are solid plans to make it compatible with the Hydraulic transmission.
What we're doing though for our own H2B CRX is to use half of the YS1 Cable casing for the mount to bolt on to. The other half would be a hydro trans half with the Hydraulic trans gearset. We're installing the Evolution/Tilton H2B clutch setup so we're using the Tilton hydraulic release bearing as well, eliminating the clutch fork setup.
We're also developing the bracket to adapt the Tilton Master Cylinder with the current Clutch pedal assembly.
Thats our solution at this time and it works out for us since we wanted to run the Tilton Hydraulic bearing kit anyways with our Tilton Twin Disc Clutch.
Old Mar 10, 2009 | 09:41 AM
Old Mar 14, 2009 | 07:32 AM
Old Mar 15, 2009 | 10:03 AM
PM'd
Old Mar 17, 2009 | 07:41 AM
Old Mar 26, 2009 | 05:20 PM
raidacaipo's Avatar
hey I pm'd you.. check your inbox
Old Mar 30, 2009 | 12:39 PM
hionvtecxda6's Avatar
Old Apr 1, 2009 | 02:33 PM
bump
Old Apr 7, 2009 | 03:49 PM
bump
Old Apr 8, 2009 | 11:11 AM
Old Apr 9, 2009 | 06:30 PM
bump
Old Apr 15, 2009 | 02:01 PM
street dreams's Avatar
From: chillin in that city called queen creek, but homes the atl
hows it going Will are u going to keep ignoring my phone calls. i have left u numerous messages and not one return phone call. And when i do get u on the phone u tell me your going to call me right back, but never do. All i want now is my money back for the h22 arias pistons that i returned back to u. sorry that it has come to me having to post in your threads but i don't like being dicked around. and if u have some how forgot who i am my name is kenny g the guy who needed the custom 88mm arias h22 pistons. but not anymore i just want my money back. like u said u would do
Old Apr 15, 2009 | 08:38 PM
me and Will have spoken and the issue is being resolved
Old Apr 18, 2009 | 04:49 PM
NABeastRR's Avatar
pics of the ef h2b crank pulley & how much?
Old Apr 27, 2009 | 07:21 AM
Will get that for you ASAP.
