lug nut stripped
Old Feb 18, 2009 | 11:08 PM
Homotor's Avatar
Default lug nut stripped
i have a lug nut that uses a key and stripped the inside of the nut and now the key spins freely, i need to kno a good way to remove it so i can change my wheels
Old Feb 18, 2009 | 11:34 PM
FIGARILA's Avatar
Default Re: lug nut stripped
is the lug nut recessed...like in a hole? can you get us a pic? there is a few ways to do it
Old Feb 19, 2009 | 03:55 AM
kyden's Avatar
can you fit a turbo socket over the lug nut?
Old Feb 19, 2009 | 11:15 AM
fcm's Avatar
fcm
Old Fart
Pix. 94
Old Feb 19, 2009 | 08:04 PM
BEYAAAH's Avatar
Take it to a local tire garage. I'm sure they have a lock removal tool of some sort. Bet they would only charge you a couple of bucks to do it.
Old Feb 20, 2009 | 07:28 AM
philafelman's Avatar
if the lugnut just spins on the stud, you'll probably have to drill it...i cant think of any other way to do it without ruining the wheel.
Old Feb 20, 2009 | 08:49 AM
mouab18c1's Avatar
depending how much its sticking out...id say use a vise grip
Old Feb 20, 2009 | 12:29 PM
jadegreendc5's Avatar
i had the same problem a while back i couldnt get it off for the life of me and i had got a flat tire, so i did what i had to do and just pried up and down and broke off the the lugnut and the stud and just replaced it. Its a cheap fix and only took about 15 -20 minutes
F20Cdriver
Oct 7, 2011 03:32 PM
CIVICRicerBoy
Feb 19, 2009 10:08 AM
shooitzlinh
Mar 20, 2005 06:44 PM
ITACivic
11
Apr 14, 2003 04:41 PM
BrandonClaps
Aug 29, 2002 08:50 PM
