OBD1 - OBD0 Gauge Cluster Pinout
ok i ripped out the old SI harness for an obd1 harness and have everything plug and wired in,
motor starts fine runs fine, but the cluster is where im stuck
does anything know the repin for both the plug in the back of the cluster from OBD1 to OBD0?
this way i can use the stock gas and temp gauges, and so my check engine stops blinking when i use the turn signals.
yes i swapped out the old harness for a new harness that we be more plug and play friendly with newer motor, and would need less custom wiring to get a motor running
89crxsi89
Aug 4, 2008 08:28 PM
