Flat faced valves flow characterisics
Old Feb 18, 2009 | 06:29 PM
lude98SH's Avatar
Default Flat faced valves flow characterisics
I know there have been many people saying that the added compression is not worth the extra weight in the valvetrain, but I heard DonF mention awhile back about flat faced valves actually having better flow characteristics on the exhaust side if this is true it changes things alot.
Old Feb 18, 2009 | 08:42 PM
squeezedeghatch's Avatar
Default Re: Flat faced valves flow characterisics
I definitely want to hear about this, as I have the supertech flatface valves. More info!!
Old Feb 18, 2009 | 11:56 PM
Combustion Contraption's Avatar
like so many things with engine building/cylinder head flow, "it depends". You probably wont get a real good answer from anyone on here that really knows. If you REALLY want to know, send me a set of flat faced valves, and $100 and i will flow them against stock valves on a stock B16 head that I have here. Ya gotta pay ta play!
Old Feb 19, 2009 | 03:38 AM
egb18c5's Avatar
i dont port heads, but thinking about does make sense. but then again, there's a lot of things that made sense and didn't make a difference.
i guess its back to the good old trial and error
Old Feb 19, 2009 | 05:26 AM
GoldLudeRay's Avatar
well aftermarket valves are lighter than stock ones so im sure
the extra material on the valve make them about the same weight as
a stock valve
Old Feb 19, 2009 | 10:40 AM
idk, i dont think companies like skunk and supertech would make products that they know are useless, im sure it has some kind of benefit. It just depends on the setup I suppose.
Old Feb 19, 2009 | 10:43 AM
How would it be "useless" if it flowed a few CFM less than stock? They still will seal, and enable you to add compression without changing pistons or skimming the head. Im not saying that any of them do flow less than stock, but if they did, they would still be far from useless.
Old Feb 24, 2009 | 05:23 PM
lude98SH's Avatar
anyone else have any info on this ? Or even the weight difference between a flat faced valve, stock aftermarket valve and a OEM valve. I think that would be interesting.
Old Feb 25, 2009 | 03:40 PM
idk, i DONT think companies like skunk and supertech would make products that they know are useless, im sure it has some kind of benefit. It just depends on the setup I suppose.
What i was saying is that those companies would not make valves if they did not produce some kind of benefit, whether it be light weight or raise compression.
Old Apr 4, 2009 | 01:57 PM
lude98SH's Avatar
back from the dead bump
Old Apr 4, 2009 | 02:52 PM
Lubo_25's Avatar
grab a precision weighing scale to the 0.1 grams and check the static weights...
also depending on how many valve jobs you've had you might actually lose compression...so be careful...
lighter, dished valves for the win...
cheers
Lubo
Old Apr 4, 2009 | 03:05 PM
So youve done this then I suppose? What weighs more? A flat faced , standard sized SUPERTECH valve, or a stock ITR valve?
Old Apr 4, 2009 | 04:10 PM
vinuneuro's Avatar
Just curious, are there any OEM or factory race engines in the world (Honda or otherwise) that use flat-face valves?
Old Apr 4, 2009 | 04:32 PM
d15Beta's Avatar
steve, i may hit u up on that offer.. flowing flat valves vs oem valves hehe
Old Apr 4, 2009 | 04:41 PM
lude98SH's Avatar
Actually if anyone else is willing to put up some money I have a stock h22 head that I wanted to flow anyway. I have OEM h22 valves. I just need some flat faced valves, the only ones I have are in my motor. This will also help all stock head guys in camshaft selection.
Old Apr 4, 2009 | 07:01 PM
00Red_SiR's Avatar
All Motor Mentor
I'd be up for CC doing the flow test and seeing the difference.
From what I know, it has to do with the way the air flows around the valve head. A dished (standard/stock style) intake valve allows the air to flow around it more quickly due to it's shape. The exhaust valve flows better if it's flat or even bubbled slightly since the air moves in the opposite direction over the valve head. When the valve is dished like stock, it can "cup" the airflow and slow it's exit speed.
I'm sure CC or don F could give a more technical explaination of what I'm trying to say.
Old Apr 4, 2009 | 07:07 PM
mikesrex's Avatar
seems like it would be pretty easy to model the system using some computer software to see what flows better
Old Apr 4, 2009 | 07:31 PM
nikko_SOHC's Avatar
so wouldit make sense to buy a set of flat faced exhaust valves and a set of dished intake valves? if this theory were true.
Old Apr 5, 2009 | 04:47 AM
00Red_SiR's Avatar
All Motor Mentor
Yes. That is how my new head is set up, however I would go with whatever my head porter/builder suggested.
Old Apr 5, 2009 | 09:46 AM
nikko_SOHC's Avatar
does your setup have all aftermarket valves or a combo of oem and aftermarket?
Old Apr 5, 2009 | 02:31 PM
00Red_SiR's Avatar
All Motor Mentor
All aftermarket but the intakes are just stock replacements to the best of my knowledge. Similar shape and design, nothing really special, just replacing them at the same time as the exhaust and are probably less expensive than the stock ones.
namewasdallas
15
Apr 30, 2011 04:14 AM
thegatekeeper14
Dec 28, 2010 09:41 AM
junkyard racer
Sep 7, 2008 04:41 PM
ZoRG
Jan 23, 2004 09:41 PM
Smoothy
Sep 23, 2001 05:38 PM
