J&S SafeGuard Problems ...
Old Aug 9, 2002 | 05:22 PM
kungfuSiR's Avatar
Default J&S SafeGuard Problems ...
Well i got my J&S UltraSafe Guard Version 2 earlier this week
It's the second one i've hooked up, i hooked up a friends also
Got everything tap'd and spliced, and went to go test the car out, and i ran into a problem.
Every time i rev the car (Only at WOT) at about 5,000RPM the ignition or something gets cut and the car hesitates, and then all of a sudden takes back off. It does it a little bit at 6,000RPM also. Now I have the sensitivity on the J&S Turned ALL THE WAY DOWN, and i know my car is not knocking that badly. Plus the J&S Dual Monitor, is not saying that it's pulling timming.
I unhooked the J&S, and went out for a test drive and the car was fine again.
Does anyone have any idea what the hell this could be that's making my car do this?
Old Aug 9, 2002 | 05:26 PM
champITR's Avatar
From: If ignorance is bliss... I am in the happiest, place on earth.
Default Re: J&S SafeGuard Problems ... (kungfuSiR)
anything else hooked into the ignition wire?? anywhere on the ignition wire.
later
matt
Old Aug 9, 2002 | 05:46 PM
kungfuSiR's Avatar
Default Re: J&S SafeGuard Problems ... (champITR)
Nope nothing
Just my J&S Safeguard
Old Aug 9, 2002 | 05:53 PM
Batoutahell's Avatar
Try adjusting the rev limiter on the J&S.
Old Aug 9, 2002 | 05:59 PM
kungfuSiR's Avatar
Default Re: J&S SafeGuard Problems ... (Batoutahell)
There is no rev limiter on the J&S
Old Aug 9, 2002 | 06:22 PM
uNF$@#!'s Avatar
bad wiring? the J&S is probably retarding your timing from the stock knock sensor being the crap it is?
edit: read your post more carefully. if its not retarding the timing then i would def check the sensors or your butt dyno isnt accurate
[Modified by Soup ****, 10:26 PM 8/9/2002]
Old Aug 9, 2002 | 06:55 PM
The 1st gen J&S had a rev limiter. I just took at guess that the 2nd gen does too. My bad. Good luck.
Old Aug 9, 2002 | 08:37 PM
mingchi96
Guest
Posts: n/a
get rid of that pos JS safeguard. that'l solve your prolbem. I had it on my b20/vtec.. which is a naturally loud motor.. and even with the settings turned down all the way (it was with a js safeguard knock sensor), the JS always kicks in.. for no reason.. and it sucks. You think it's all wow.. its doing its job.. but when you race against somebody, and you feel your JS safeguard kicking in.. and the guy you are racing is smoking you because something is holding your engine back.. you will start to get very annoyed.
My JS always kicked in when I shift hard, and just randomly come on cause it feels like it. Honestly.. the JS safeguard cant really stop detonation alltogether, it's just annoying. Just get your car tuned properly so you wont have any worries with detonation, and then junk the JS safeguard. I've had the JS safeguard off for over 1+ yr now.. and not a problem with my motor at all.
Old Aug 10, 2002 | 08:55 AM
kungfuSiR's Avatar
Default Re: J&S SafeGuard Problems ... (mingchi96)
The only reason why it was kicking in soo much is probably because you had the sensitivity turned up way to high, or you were actually knocking
I fixed the problem anyway, it had to do with the vacuum line, i didn't need it because i'm not running boost, and because Version 2 doesn't have the selector between NA/FI mode, it kept freaking out when my motor wasn't creating boost etc etc ...
So all fixed and i'm ready to go
Old Aug 10, 2002 | 10:30 AM
mingchi96
Guest
Posts: n/a
no.. my sensitivity was turned down all the way, and i did torque the knock sensor right (20 ft/pds if i believe), and no i'm not detonating.. unless I have been detonating for 1+ yrs now and not burning oil, and still really high compression. In that case, i guess detonation is a good thing
Old Aug 10, 2002 | 10:58 AM
green_GSR's Avatar
...but you do know that a motor will behave differently in different weather conditions, right? So maybe your motor was really detonating at the time?
From what I have read and heard so far, the only people complained about J&S is the version 0...pulling the timing for no apparant reason. However, there was a defect in version 0, which is corrected in version 1 and beyond.
I have a few friends who are running J&S version 1, and they absolutely loved it.
Old Aug 10, 2002 | 11:02 AM
kungfuSiR's Avatar
Actually when a car is knocking it is making it's most amount of power, but that doesn't mean it's a godo thing for your motor ...
anyway
i have a feeling you just didn't know how to setup your J&S
J&S Saves motors and that's a good thing
H22AllDay24
May 28, 2018 09:40 AM
celavi
May 11, 2012 09:49 AM
citystars41
Jul 28, 2008 06:44 AM
Urban Business
24
Oct 3, 2002 01:11 PM
