What Flywheel and clutch to run with 450-500HP?
Old Feb 18, 2009 | 03:30 PM
Silvertc's Avatar
Default What Flywheel and clutch to run with 450-500HP?
My goal is looking to push 450-500HP Turbo'd B16 built. I'm unsure of which Flywheel to run. Someone told me an ACT Prolite. But anyone tell me what their running?
As for Clutches I think I'm going to run a Competition Stage 5 clutch and pressure plate. But any input or someone who has expeirence with this or other clutches would be greatful!
I would be very happy for the input, thanks guys.
Old Feb 18, 2009 | 03:45 PM
turbo-crx's Avatar
Default Re: What Flywheel and clutch to run with 450-500HP?
cc stage 5
Old Feb 18, 2009 | 03:51 PM
chippinpressure's Avatar
flywheel i would keep stock if possible only because your rpms dont drop as fast while shifting thru gears and the motor tend to stay up in high r'ss, and another thing if you do use a lighten flywheel try not to use a lighter pully togetrher it could un balance the motor .as for the clutch good choice ive had good experience with it . if that dont hold twin disc it is.this is just my opinion just to give u an idea. good luck with ur build.
Old Feb 18, 2009 | 03:53 PM
purpleh22's Avatar
Spec stage 3+. I'm using one on my 92 hatch that has an H22 with 530whp and 435 wtq. Go to the Spec website and check out specifications for your application. Super streetable. Clutch disk is full face (not puck type) and has a ceramic metallic facing - I think. Great holding power, light pedal pressure and doesn't grab or chatter at all. I think it is significantly easier on flywheel/pressure plate surfaces than most puck type clutches.
Old Feb 18, 2009 | 07:59 PM
Silvertc's Avatar
ok thanks guys, anymore input on what flywheel to run?
Old Feb 18, 2009 | 08:09 PM
90blackcrx's Avatar
Comp Clutch, or act
Old Feb 18, 2009 | 08:28 PM
D16SohcVtec's Avatar
Action clutch
Old Feb 18, 2009 | 08:34 PM
streetracer6rpt's Avatar
cc clutch.. stock flywheel
Old Feb 19, 2009 | 07:01 AM
Silvertc's Avatar
so some are saying stock flywheel, is it bad if i run a lightened flywheel?
Old Feb 19, 2009 | 07:33 AM
Schister66's Avatar
Man U FTW
Originally Posted by turbo-crx
cc stage 5
I'm looking for the same power range and went with the same clutch. It's cheap and will hold just fine..
Old Feb 19, 2009 | 07:58 AM
Ls_dx's Avatar
I had 375 whp and loved my CC s5, its going into my new build. mated up to my stock flywheel... honda doesnt make junk. I say roll with a stock (resurfaced) flywheel
Old Feb 19, 2009 | 08:35 AM
Full-Race.com's Avatar
Competition Clutch FTW!
Old Feb 19, 2009 | 09:16 AM
SovXietday's Avatar
No, I run a lighter flywheel in my D. Only reason was because I got if for cheap way back in the day when LSD was selling them for like $100. Unless you can get one for cheap I wouldn't waste my money.
Oh and I run an Action 2MD.
Old Feb 19, 2009 | 03:17 PM
tegman23's Avatar
Act flywheel here..Made 400whp with it and loved it, going for 500whp this year same flywheel
Old Feb 19, 2009 | 09:55 PM
V-SPEC 1's Avatar
made 540whp on ACT streetlite flywheel 400 trq.
vgsr
Jan 5, 2012 03:51 PM
Silvertc
Transmission & Drivetrain
Feb 18, 2009 08:29 PM
gmadsen100
15
Nov 7, 2006 09:05 PM
super_mut
May 9, 2006 10:15 PM
lkailburn
44
Sep 28, 2004 12:02 PM
