EK auto tranny removal??????
EK tranny removal. I am takin an auto tranny out and the only thing holdin it there is the cable that select gears and ****. How do i remove the cable safely without cuttin or breakin it. cuz the tranny need to go back in for the time bein. Help me out guys. Thanks.
follow where the cable goes into the tranny. there should be a plate that is blocking the inside where the cable connects. i think 2 or 4 bolts i forgot. that plate should come off and then where the cable connected to theres a screw that screws the cable onto the tranny. unscrew that screw but you might have to bend a piece on the nut to make it fit because its bent just stick a flat head screw driver and pry it...
4dohs4mohoes
Apr 14, 2004 09:45 AM
98DC2teg
Feb 22, 2004 09:51 AM
