Car Wont Keep Idle (Hot or Cold)
Old Feb 17, 2009 | 09:39 PM
the_0ne's Avatar
Default Car Wont Keep Idle (Hot or Cold)
I have a LS/VTEC swap with a GSR head, running on a stock JDM b16 ecu into a 96 civic cx hatch.
The car doesn't hold a idle (need to keep revs up or it dies)
This is what was done to try to fix it:
Replaced Ecu with 2 others (including p28)
Replace Dizzy/Plug Wires/spark plugs
Replaced injectors,fuel filter,fuel rail,filter
Replaced the whole engine harness
I tried 5 different IDLE CONTROL VALVES
New TB/ IM GASKET
NO vac leaks!
Cat isnt clugged
Compression is 180 - 180 - 150 - 145
Timing is fine
Only thing I can think of it the TB gasket isnt OEM, I am so puzzled with this car, I need any ideas on what to try next.
vrrodri
Aug 20, 2018 07:06 AM
b16_civicjosh
May 10, 2011 07:38 PM
tothewall
Oct 7, 2010 12:43 PM
89 CRX SI
Dec 14, 2002 05:35 PM
SpoolnG2
Oct 17, 2002 09:49 PM
