Signs and symptoms of a motor going bad
Old Feb 17, 2009 | 06:37 PM
93_hatchie's Avatar
Icon6 Signs and symptoms of a motor going bad
I have a 99 Civic Si with 180K miles. Last winter I started hearing a noise coming from my motor that sounded like a zipper. It would speed up/slow down with the engine RPMs, didn't matter if the clutch was engaged or dis-engaged. I thought it was something with the timing belt, so I had that replaced last summer (it was due for it anyway), and also had the mechanic check out the engine at the same time. He said the engine was solid, compression was good. He thought it needed a valve adjustment (probably because of the noise), but found that it was within normal ranges and did very little adjustment, but the noise was still there.
Yesterday morning, I noticed that the sound was significantly more noticable, to the point of annoying. It now sounds like a cross between an alternator whine and supercharger whistle. I don't have a supercharger and the alternator was replaced a couple years ago, before I had the car. The noise also does not get worse or fade out when electronics are turned on and off. It starts getting noticable at about 2500 RPMs, and gets worse from there. It was the same today, and sound exactly the same after the car is warmed up.
I don't drive the car hard, and I keep up with maintenance on it.
Any idea what could be happening here?
Old Feb 20, 2009 | 07:20 AM
93_hatchie's Avatar
Default Re: Signs and symptoms of a motor going bad
Just had the car at the mechanic. A/C pulley (tensioner) went bad.
Old Feb 20, 2009 | 07:24 AM
philafelman's Avatar
kinda sounds like a pulley is going bad....did you replace the water pump with the timing belt? could also be the tensioner pulley or one of your accessory pulleys...you could pull off the drivebelts and see if it still makes the noise to eliminate or pinpoint the possibility of your a/c, alt., or p.s. pulleys.
Old Feb 22, 2009 | 10:50 AM
NAHHHHH's Avatar
i have this exact same problem and the exact car but mione has 53,000 on it
Old Feb 23, 2009 | 01:37 PM
93_hatchie's Avatar
Yep, it was one of the A/C pulleys. Not the one on the compressor itself, but there's one just off the compressor.
mreed
Jan 16, 2023 09:02 PM
OSIRIuS23
Jan 18, 2013 05:26 AM
Blackdogz
Dec 10, 2007 02:37 PM
shadohconspiracy
15
Oct 11, 2007 03:48 PM
VIS250P
Jan 4, 2005 01:21 AM
