itr 98spec header fitment
i am getting a 98 spec itr header and a new catalytic converter. my question is will it bolt directly on a obx cat converter? the header is 2.5 collector. the catalytic converter, an obx high flow one for a 96-00 civic, is a 2.5 inlet and outlet. i assume it will, right. heres the link:
http://www.sparktecmotorsports.com/cat101c.html
for header components here is the the link:
http://inlinefour.com/25incolflan.html
thanks
thanks
hey what kind of exhaust are you using with that cat????
and if the inletis 2.5 and the header is 2.5 then im 100% that it will fit i mean did you even think about this before posting
yeah i was just going to ask about that fitment too. but im pretty sure it does. if you click on the link for the cat, under the description it says "Compatible with all stock and aftermarket exhaust systems and headers"
$amGD3
Aug 29, 2010 05:46 PM
