H22 head with h23 block dyno results!!
Old Feb 17, 2009 | 04:41 PM
mike97lude's Avatar
New User
Default H22 head with h23 block dyno results!!
I just wwanted to let everyone know my dyno results for my car. Its a 1997 prelude base 5 speed. I have h22 vtec head and h23 block. h22 jdm pistons hoaned, connecting rods bored. hondata s100 tuned by king motorsports and its dynoed at 193 and 162.
I kknow alot of you were interested in those numbers so there they are!
Any ideas of what that may run on the track?
Old Feb 17, 2009 | 05:04 PM
Kronn 98SH's Avatar
Default Re: H22 head with h23 block dyno results!!
Approximately 4.7 seconds (in the 100-meter dash)
Old Feb 17, 2009 | 05:11 PM
98vtec's Avatar
moderator emeritus
post a graph.
Old Feb 17, 2009 | 09:04 PM
95greenlude's Avatar
with 193...maybe a 14.0 with street tires
yea, but post that graph
Old Feb 17, 2009 | 09:07 PM
RGSH22ACCORD's Avatar
post a graph lets see that
Old Feb 18, 2009 | 05:26 AM
mattsnooz's Avatar
Go track it lol. We don't know how well you drive. Car's only as fast as the driver is good.
Clean up launches and shifting and you can shave .2-.5s off your quartermiles (depending on how bad you sucked to how much better you can get with practice)
Shifting in bare feet works good. Shifting in work boots...not soo good. I'm glad I got a beater and don't got to take my prelude to job sites anymore :D
Old Feb 18, 2009 | 05:59 PM
hondabigblock's Avatar
This thread is useless without dyno graphs
Old Feb 19, 2009 | 04:47 AM
ssaccord92's Avatar
That dyno seems low. What type header and exhaust are u running. What throttle body and intake mani are u using also with this build did you use a stock head gasket or cometic custom headgasket. With stock head gasket it should be 11.6 compression. Also i would love 2 see u do a compression and leak down test to see what the results are. But it's a good start 2 making power. u should gain from good header intake mani and tb upgrade and also upgrading the exhaust 2.5 or 3inch.
Old Feb 20, 2009 | 01:36 PM
mike97lude's Avatar
New User
I have a dc header and apexi n1 exhaust with a megan straighpipe aem v2 intake.....and it has a cometic gasket
Old Feb 20, 2009 | 03:10 PM
japscrap's Avatar
Soooo not much. A better exhaust will get you a lot more.
Old Feb 23, 2009 | 05:02 AM
ssaccord92's Avatar
how thick is the head gasket do u remember
Old Feb 27, 2009 | 08:03 PM
mike97lude's Avatar
New User
I dont know they just said it was a aftermarket cometic gasket..?
Old Mar 2, 2009 | 04:19 AM
ssaccord92's Avatar
U need to find out how thick the head gasket was that could be affecting what ur compression is . Power could be gain from that alone. Also do a compression test and let us know ur results
pkolaboy
Feb 19, 2008 06:37 PM
preludefien
Sep 9, 2007 09:19 PM
99accord241
Jun 30, 2005 08:49 AM
H23LUDE92
Jul 14, 2004 08:19 PM
JdmAcclude
Apr 29, 2002 08:16 PM
