Car is missing and running rich
Old Feb 17, 2009 | 04:08 PM
dudeomega2000's Avatar
Default Car is missing and running rich
I posted a previous thread about a problem with my car but i am reposting a new thread with more knowledge. My car is misfiring and running rich. I did a fresh rebuild on the ls motor in my obd2 teg. It was missing b4 the rebuild but i am stumped. The computer is throwing 3 sets of codes.
Random Misfire in cylinder 3 and 4
Random Misfire in Multiple Cylinders
and code p0113 which is the IAT
The car only misses while its idleing. Runs fine. I am stumped until i did the code reading. Will the IAT cause this many problems. I am basically running stock execpt with I/H/E and test pipe.
I have already changed plugs, wires, and injectors. I am leaning towards the dizzy right now but before i spend 300 bux on a dizzy i want more info and input.
Old Feb 17, 2009 | 04:09 PM
MumBleZ_94gsR's Avatar
Default Re: Car is missing and running rich
first change the IAT
Old Feb 17, 2009 | 08:18 PM
do u think that would cause me to have all these problems?
Old Feb 19, 2009 | 12:17 PM
Just changed IAT and still the same crap.
Old Feb 19, 2009 | 12:22 PM
Jimmy's Avatar
Global Moderator
Pull the spark plugs again and inspect.. You could of fouled them
What ecu are you running..
Are you running a FPR or fuel pressure gauge?
Old Feb 19, 2009 | 01:49 PM
The ecu is the stock one... i think its a p72 if i am not mistaken. Whichever comes on the ls integra in 98. I have the stock regulator as well
Old Feb 20, 2009 | 05:24 AM
Does anyone think it might be the computer? Whenever i reset the computer the car runs fine for like 2 minutes and then it starts to act up all the time.
Old Feb 20, 2009 | 11:47 AM
racebum's Avatar
typical of bad wires - dizzy issues. even a bad plug. i've seen wires that get pulled a little too hard cause exactly this.
Old Feb 21, 2009 | 05:23 AM
I consulted the honda manual. A random misfire would not be a dizzy problem because this only happens while accelerating. Low rpm or on load misfire would be IACV, vtec system, fuel pressure, or valve clearance.
Old Feb 21, 2009 | 07:23 AM
Dogginator's Avatar
Daisy... Daisy...
You could have a bad injector or injector wiring. A misfiring injector will cause and missfire the other cylinders to run rich.
Old Feb 21, 2009 | 04:12 PM
Bro... to be honest i believe u r right. I just finished swapping out the plugs, wire, dizzy, computer, IACV and nothing. I think it may be the wiring. How do i check that?
Old Feb 21, 2009 | 04:23 PM
Dogginator's Avatar
Daisy... Daisy...
Check for proper ground and continuity between the ECU harness and injector plug with a multimeter.
Old Feb 21, 2009 | 04:36 PM
do they make cables that long?
Old Feb 21, 2009 | 06:14 PM
Dogginator's Avatar
Daisy... Daisy...
LOL. Yes. You can use any piece of wire for a multimeter jumper.
Old Feb 21, 2009 | 08:12 PM
ah true.
Old Feb 24, 2009 | 03:46 PM
gonna try to switch it to obd1 to see if it runs better.
Old Feb 26, 2009 | 08:53 AM
i give up!
Baron55
Jul 2, 2007 02:32 AM
5genprelude
Mar 24, 2006 09:22 AM
Mik3
Jan 26, 2006 06:35 AM
B00ST2nR
Oct 19, 2002 02:36 PM
