vaccum leaks?
aight i think i fixed my idle problem but i still have some vaccum hoses not pluged back up ... i re did all the ones on the TB and IM ... so there good now .. i also relocated the mapsensor and fuse box back into the engine bay just because the hose that was on the map sensor was liek 2ft long and it kept comming off so i made it alot shorter and it doesnt come off now when i put it back in the engine bay ...
but here is one hose i noticed still not pluged up and idk where it goes ... its attached to the top of the tranny ... do you know where it might go .. thanks
thisis where its hooked to the tranny its on the top front
bottom pic is sideways ... and this is basically like right under the dizzy
i know its kinda got alot of oil aroudn the area and idk why it does cause there isnt il anywhere else .. could you also help figure that out .. thanks
From: I told you to wait in the truck in Texas, United States
That is just a vent for the transmission.
It just hangs there..
Tell us what year/engine/trim level etc.
and maybe we can find you a vacuum map.
here are a couple: https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/diagram-service-manual-si-intake-manifold-1052937/
oh aight ... well theres somethign hard in my hose so i think its clogged .. so im gonna replace it tomm. but where do you think that oil is comming from ... ti is only right there .. none on the block or anythign just that spot under the dizzy on the tranny ...... and i dont need a vaccum diagram i got everythign else correct i believe
how do i check to see if thats the problem cause i wann aclean up my bay so there isnt any oil anywhere and its not worth cleaning if its leaking somewhere
Cleaning up the mess is how you will find it..
Get it spotless and it should be easy to locate the leak..
I have seen the oil coming from inside
the distributor cap in some cases..
illicit^
May 20, 2007 07:06 PM
stripes777
Jan 22, 2004 08:21 PM
