Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
New Brakes doing clap,clap,clap sound
Old Feb 17, 2009 | 01:37 PM
hardboiled's Avatar
Default New Brakes doing clap,clap,clap sound
Hiagain
Bought brake pads brand Prostop platinum at pepboys
Newly installed pads & rotors, Pads came with the back metal plate and i install it together. Does any know if the metal Backplate on the pads is making this type of clapping sound ? it happen around 0-15mph when i hit brake pedal and let it go and sometimes from 0mph to 15mph
any ideas anyone? could it be the cvjoints ? i recently change passenger side Wheel bearing and drivers Bearing seems damage too
Old Feb 18, 2009 | 12:35 PM
Whatislove's Avatar
Default Re: New Brakes doing clap,clap,clap sound
are they pitted? cause they can make a popping noise where hot air gets trapped and expends when the rooter goes over them.
Old Feb 18, 2009 | 12:48 PM
hardboiled's Avatar
Both pads and rotors i install it new, the pads came with a bit of dark grease and i applied on contact sides of the pad. The old pads had some type of red rubber glue on then and i clean it.
Just a while ago i was driving and the sound became more constant and i thought after adjusting more tight the rear DRUMS this problem appear?? I feel like the rear brakes are more tight than the front, do you think this can be the problem making the PADS separate from the sides and start clapping ?
Old Feb 18, 2009 | 05:38 PM
pon55's Avatar
Loose caliper bolt?
Old Feb 18, 2009 | 06:15 PM
hardboiled's Avatar
no cant be, all the bolts are tight in place
the hell i never have luck with anything i do
Old Feb 18, 2009 | 06:48 PM
Whatislove's Avatar
my suggestion would to to take it apart and put it back together again. maybe something you missed or not aligned.
Old Feb 18, 2009 | 07:55 PM
hardboiled's Avatar
should i use the rubber paste to glue the pad to caliper?
or should i take off the pads backmetal plate attached to it?
DC4R27
Suspension & Brakes
Apr 21, 2009 05:52 PM
PatrickGSR94
Suspension & Brakes
Jun 2, 2008 03:17 AM
Dogginator
10
Sep 1, 2005 09:09 PM
Mr. Projekt
Honda S2000
10
Jan 18, 2005 12:27 PM
Red94Sedan
Mar 7, 2003 10:00 AM
