Need some help with an 91 civic hatch
Old Feb 17, 2009 | 05:50 AM
frontwheelfanatic's Avatar
Default Need some help with an 91 civic hatch
problem solved.
problem=bad ignition switch
Old Feb 17, 2009 | 06:16 AM
jlicrx's Avatar
Default Re: Need some help with an 91 civic hatch
is ground wire from harness at thermostat housing connected?
Old Feb 17, 2009 | 06:36 AM
90civichbsi's Avatar
have you tested the pins at the injectors to make sure they are getting power?
I would get out a multimeter and start checking for power signals to try to determine where you are still getting a signal. Its possible it could have shorted the injector resistor box as well.
so check:
1. Signal at the injectors
2. Signal before the injector resistor box
3. Signal at the ECU
that should narrow it down for you a bit.
it might be best to leave the connectors plugged in and just poke a safety pin through the wire to get your signal so the circuit stays complete.
Orangevirus1
Jul 9, 2013 07:55 AM
mickey b16
May 26, 2009 04:02 PM
BlownBlackSi
Sep 30, 2006 01:28 PM
blu3g
Feb 15, 2006 11:14 AM
berettagtz117
May 1, 2004 10:40 PM
