92 Civic Sedan (Should I go H22 or B18c?)
Old Feb 17, 2009 | 12:40 AM
92-CivicLX's Avatar
Icon2 92 Civic Sedan (Should I go H22 or B18c?)
I'm new to the Honda world and I purchased a 92 Civic Sedan last year and now it's time to begin the project. The 1st thing I wanna do is get an engine/tranny swap but can't decide between an H22 or B18c. Can someone tell me the Pro's and Con's of both swaps? I know the H22 will require some mods but will the handling be a huge issue? Hope I can get some detailed feedback
thanks
Old Feb 17, 2009 | 12:46 AM
andoxviii's Avatar
Default Re: 92 Civic Sedan (Should I go H22 or B18c?)
I got this information from the engine FAQ thread that is stickied at the top of the forum:
B18C1 (or JDM B18C)
These come out of an Integra GSR.
Pros
Good Hp and TQ numbers (170, 121 ft/lbs respectively)
DOHC VTEC
Tons of potential
High revving
Cons
Expensive
Becoming moreso as people keep scooping them up
Slighty longer tranny than the ITR and B16
H22/JDM F20B
Pros
200 hp
H22=156 ft/lbs torque
F20B=145 ft/lbs torque
Great torque
DONT WEIGH THAT MUCH MORE THAN A B SWAP!!
https://honda-tech.com/zerothread?id=684550
Cons
Harder to install than a B/D motor
transmission feel is vague IMHO
Less info out there for the swap (aka, less experience as they are less common)
Price of swap is comperable to a B18C5 after everything is said and done (mounts, etc)
Old Feb 17, 2009 | 04:50 AM
EJdrew's Avatar
^^^ Very good info.
Old Feb 17, 2009 | 12:22 PM
92-CivicLX's Avatar
andoxviii, I don't think we're talking about the same B18C engine. Doesn't the JDM B18C engine have 200 HP/ 137TQ w/Rev-limit: 8,900 rpm?
Old Feb 17, 2009 | 12:35 PM
andoxviii's Avatar
Oh ok, well you never specified which B18C engine. In North America, all Honda engines have a number after the letter. A GSR engine, for example, is a B18C1, and a Type-R engine (which you are talking about) is a B18C5. In Japan, though, both of those engines are simply called a B18C because they have no number after to distinguish them.
Old Feb 17, 2009 | 12:36 PM
andoxviii's Avatar
Here are the Pros and Cons of the B18C Type-R engine:
B18C5 (or JDM B18C)
This is found in the Integra Type-R. IMHO this is the best swap for a Civic.
Pros
GREAT HP and TQ numbers (195 and 134 ft/lbs)
High revving
Hand built motor from Honda
Optional factory LSD
Best transmission for a B series from the factory
Red valve cover
Cons
EXPENSIVE
If JDM ITR is used, the 36mm axle 32mm hub problems occur
Old Feb 17, 2009 | 12:41 PM
92-CivicLX's Avatar
Excuse my ignorance but what it is "JDM ITR"?
Old Feb 17, 2009 | 12:43 PM
andoxviii's Avatar
JDM means Japanese Domestic Market. That means the car was made to be sold in Japan.
ITR means Integra Type R.
Old Feb 17, 2009 | 12:57 PM
TheRappist's Avatar
Red valve cover, that adds 1.5 hp. and .4 ft-lbs
Old Feb 17, 2009 | 12:59 PM
andoxviii's Avatar
Oh, and with regards to the redline, a B18C Type R engine revs to 8400 rpm.
Here is a picture to help...
Integra Type-R:
Here is a Spoon cluster which shows the redline you may be thinking of:
Old Feb 17, 2009 | 01:02 PM
andoxviii's Avatar
Haha...yeah I don't necessarily agree with the pros and cons 100%. As I said, I just copy-pasted that info from the engine FAQ thread.
Old Feb 17, 2009 | 01:05 PM
92-CivicLX's Avatar
I knew what JDM meant LOL. I just didn't understand the ITR part but thanks
TheRappist's Avatar
Lol I know, I wasn't directing it to you, I know you copied it. It is just a funny pro
Old Feb 17, 2009 | 01:14 PM
Agent_EM1's Avatar
I'd go with B-Series if I were you.. Just an opinion.
Old Feb 17, 2009 | 03:11 PM
haveaniceday's Avatar
Go with the B!
Old Feb 17, 2009 | 05:06 PM
batallic's Avatar
H
Old Feb 17, 2009 | 05:11 PM
92-CivicLX's Avatar
Originally Posted by batallic
H
Explain why :p
Old Feb 17, 2009 | 05:23 PM
92-CivicLX's Avatar
[QUOTE=andoxviii;37446242]Oh, and with regards to the redline, a B18C Type R engine revs to 8400 rpm.
Integra Type-R:
^^^ Will that fit my 92?
Old Feb 17, 2009 | 06:22 PM
batallic's Avatar
Explain why :p
have u read the faqs
99siEM1
Oct 4, 2011 11:05 PM
delsolitude
Mar 4, 2006 08:24 AM
Decepticon217
Aug 2, 2005 08:04 AM
-_-
Jan 23, 2004 08:48 PM
The Sponge
Jan 23, 2003 12:23 AM
