Low offset wheel on 98 Accord
Old Feb 16, 2009 | 09:03 PM
MestizoRacer310's Avatar
Default Low offset wheel on 98 Accord
Thinking of getting some Rota D2s off my local craigslist. They are +25 offset. The accord is lowered on H&R Sport springs. Will this cause problems with anything? I'd hate to buy them, mount tires then find out they rub/grind/etc. on things under the car..
Old Feb 16, 2009 | 09:39 PM
wesvailco's Avatar
Default Re: Low offset wheel on 98 Accord
-just the passenger side front will rub, should be all set on the other 3.
-lol.
Old Feb 16, 2009 | 09:47 PM
Why would just the passenger side front rub?
Old Feb 16, 2009 | 10:11 PM
wesvailco's Avatar
Old Feb 16, 2009 | 11:42 PM
r.wright's Avatar
they will rub if you do not roll your fenders.
Old Feb 17, 2009 | 09:11 AM
Even with a mild drop? It's only 1.5/1.2.
Old Feb 17, 2009 | 11:48 AM
r.wright's Avatar
yes, if you are using the correct size tire for your car you will for sure rub.. you are going out about an inch from the normal stock wheel.
recommended sizes to be used on your car would be an offset of +40 to +48.
Old Feb 17, 2009 | 04:43 PM
Figured as much. I just thought I'd give it a try....I'm not willing to shell out $200 to have my fenders pulled/stretched/etc just to fit rims. And I'm also not willing to attempt doing it myself, since I've never done it or seen it done.
Old Feb 17, 2009 | 07:48 PM
r.wright's Avatar
oh, it can be done and has been done and will be done ...
it's just that you need more mods to make it work.
Old Feb 17, 2009 | 08:10 PM
Yeah, more than I'm willing to do/pay for on the wife's car...maybe mine...lol
Old Feb 17, 2009 | 09:48 PM
wesvailco's Avatar
-you still haven't stated a size of wheel or tyre size. that would truly benefit your initial question properly being answered.
Old Feb 17, 2009 | 10:27 PM
Rims are 17x7.5 and the tires are 215/45R17
Old Feb 19, 2009 | 04:12 PM
Artunique128's Avatar
New User
I WANT THOSE EXACT WHEELS FOR MY 94 accord
Old Feb 19, 2009 | 09:38 PM
r.wright's Avatar
okay now that i think about it more, normal size for that car is 205/50-17 and the 215/45 is .5 inches shorter than the 205/50 so it might work...maybe but then you may need to leave the natural camber on there in order for it not to rub in the back and for the front you may need to trim the inner plastic slightly. the wheel may be either extremely flush and/or stick out about 1/2 an inch.
z395civic
Jan 4, 2009 08:23 PM
Danger69
Oct 1, 2007 07:03 PM
SSTOLEN
May 24, 2007 02:49 AM
-RedneckDave-
Sep 19, 2005 10:40 AM
blackaccordcpe
Jun 29, 2004 05:55 AM
