ej2 speedo problem
Old Feb 16, 2009 | 08:55 PM
jerry_ort007's Avatar
Default ej2 speedo problem
last week while driving, the speedo just died from being on 35. it goes on and off... could the problem be the vss, a fuse, or the cluster.
any info will be appreciated before i spend any money on the wrong parts.
by the way... its a D15B7 with an jdm si tranny.
thanks!
Old Feb 16, 2009 | 09:15 PM
Techy's Avatar
Default Re: ej2 speedo problem
Could be your VSS or cluster but it sounds like it's doing what my old EJ1 did. I had a bad cluster. Replaced it with an LX cluster and it was fine. You can also just replace the speedometer in your cluster but I figure it's easier to just replace the whole cluster.
Old Feb 16, 2009 | 11:45 PM
99EK-T's Avatar
prob. not likely but did your battery die? my cluster would go ut before my batter was about to die
Old Feb 17, 2009 | 07:00 AM
smurfylee's Avatar
did you check your speed sensor on your tranny
mikej94civex
May 25, 2010 05:09 PM
EJ8-Yao
Engine Management and Tuning
Apr 21, 2009 05:28 PM
aziaticvang
Jan 8, 2008 06:41 PM
whitehf
May 10, 2007 08:41 PM
