Sway bar tearing frame?
Old Feb 16, 2009 | 06:07 PM
chinkyx90's Avatar
Default Sway bar tearing frame?
I have a civic 00 sedan and it doesn't come with stock swaybars(i'm sure you guys know that), what size of a sway bar should i be getting, 22mm or 24mm, and whats the difference. Also what size of a sway bar will actually tear my frame without a brace/and with it?
thanks!
Old Feb 16, 2009 | 07:15 PM
chinkyx90's Avatar
Default Re: Sway bar tearing frame?
bump
Old Feb 16, 2009 | 11:38 PM
TheJGB3's Avatar
1. The 2000 EX and LX sedans DO have a front swaybar - it is 22MM
2. I know for a fact you can purchase an Si rear bar and mount it easily on an EX or LX without replacing the lower control arms (like you would have to do for the front).
3. What do you mean tearing the mounting bracket out of the frame? I have only heard of that happening when a larger then stock bar was installed on a lowered car.
The Si rear sway bar is 13MM
Here are the parts you need
#27 is 52300-S52-A01 SPRING, RR. STABILIZER (13MM) $67.97
#30 is 52317-S04-000 BRACKET, RR. STABILIZER $9.67 --- (2 req'd)
#28 is 52308-S04-000 HOLDER, RR. STABILIZER $4.14 --- (2 req'd)
#29 is 52315-S52-A00 BUSH, RR. STABILIZER (13MM) $3.42 --- (2 req'd)
#35 is 93403-08020-08 BOLT-WASHER (8X20) $0.16 --- (4 req'd)
#36 is 95701-08018-08 BOLT, FLANGE (8X18) $0.62 ---(4 req'd)
#34 is 90212-SA5-003 NUT, SELF-LOCK (10MM) $0.36 --- (2 req'd)
#33 is 90002-S10-000 NUT, FLANGE (10MM) $1.85 --- (2 req'd)
#31 is 52320-S04-003 LINK ASSY., R. RR. STABILIZER $49.49
#32 is 52321-S04-003 LINK ASSY., L. RR. STABILIZER $45.74
Installing the rear bar will GREATLY IMPROVE handling
If you were talking about doing an Si front swaybar (which is 26MM) you will have to purchase the Si frt lower control arms, the Si frt bar, the brackets, the bushings, and the Si endlinks.
The front bar you have now is 22MM so IMHO I would just buy/install the Si rear swaybar, and maybe purchase polyurethane bushings for your front bar (22MM).
Old Feb 17, 2009 | 01:34 AM
chinkyx90's Avatar
First poster, and very helpful THANKS.
So that means that the rear only uses 13 mm? and not 24mm/22mm??
Because i was planning to get the full rear ASR sway bar+brace kit but those come in 24/22, unless i'm lookin in the wrong area.
Old Feb 17, 2009 | 05:54 PM
chinkyx90's Avatar
bump
Old Feb 17, 2009 | 06:10 PM
TheJGB3's Avatar
I reason I recommend that you get the Si 13MM bar instead of the ASR one is because it will greatly improve your handling, and will be much cheaper then doing the ASR kit. And that the ASR kit probably will tear loose from the rear subframe eventually.
Old Feb 17, 2009 | 06:38 PM
chinkyx90's Avatar
Ah ic, the price isn't the probably for my sway bars i just want whats best for my cornering =]
But yea, i heard getting the whole asr sway bar+brace kit is the best, but will it really tear eventually??
Anymore suggestions please??
Old Feb 17, 2009 | 10:25 PM
TheJGB3's Avatar
Well this is what happens...
My guess is it is from the rust on the subframe.
Old Feb 18, 2009 | 11:47 AM
chinkyx90's Avatar
okay, thanks for help!
Old Feb 18, 2009 | 01:40 PM
Christopherian1982's Avatar
looks like that person didn't have asr sub frame to go with tha sway bar
Old Feb 18, 2009 | 02:15 PM
kulo's Avatar
nasty
im running 22mm ek9 rear sway bar on st tie bar setup with es bushing
Old Feb 22, 2009 | 05:57 PM
TheJGB3's Avatar
Originally Posted by kulo
nasty
That looks like a tie bar, not a swaybar.
Old Feb 22, 2009 | 06:53 PM
KillBot's Avatar
Tearing also depends on how hard you drive your car...
Old Feb 22, 2009 | 07:07 PM
alphalanos's Avatar
the ASR sub brace and a 22mm CTR rear bar is what ive been using for a couple years and its held up fine.
Old Feb 22, 2009 | 08:45 PM
94jdmeg6civic's Avatar
asr FTW
i have had my kit on my eg but its the 32mm bar and i drive hard on it (road race car)
and about the ek its going to have more problems becasue if i remember right its only 1 layer and eg's are 2 layer of metal on the rear subframe
Midori Green
Feb 12, 2008 11:39 AM
JMelt4
18
Apr 30, 2007 07:43 PM
Rouin
Honda Civic (2006 - 2015)
Mar 11, 2007 12:51 PM
dgdarien
Mar 21, 2005 11:09 PM
katb16vo
22
Mar 25, 2004 03:29 PM
