Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
puting a 5 speed rsx trany in an 03acoord
Old Feb 16, 2009 | 04:54 PM
jdm_xsi206's Avatar
Default puting a 5 speed rsx trany in an 03acoord
i was jus wondering if the 5 speed rsx tranny would bolt right up to my 2003 accord??? and would i have to change the flywheel and the clutch??? has any one ever done this???? the reason im asking this is because there is a grinding sound thats coming form the clutch or tranny. everytime i start up the car it and let go of the clutch it would start grinding. when i put my foot back on to the clutch it stops.... it still goes in very gear and it moves kind of. i dont know what the problem could be... if anyone knows pleas help... thanks
Old Feb 16, 2009 | 08:43 PM
BWek's Avatar
Default Re: puting a 5 speed rsx trany in an 03acoord
transmissions have different mounts
Old Feb 17, 2009 | 10:54 AM
jdm_leche's Avatar
No the rsx tranny does not bolt up...the tsx tranny does...that noise might b the throw out bearing
Old Feb 17, 2009 | 11:15 AM
JDM Hunter's Avatar
yeah rsx tranny wont bolt up
why not just replace the original tranny?
just curious
Old Feb 17, 2009 | 08:21 PM
jdm_xsi206's Avatar
well i cant find a stock 2003 accord tranny... does anyone know where i could get one????
Old Feb 19, 2009 | 07:52 AM
sleeper98civic's Avatar
You can buy mine once I get my TSX swaped into my 03 sedan.
Old Feb 19, 2009 | 09:07 AM
JDM Hunter's Avatar
or you could get your transmission fixed
Old Feb 19, 2009 | 09:21 AM
senser1080's Avatar
Order the 6 speed transmission for the Accord.
Old Feb 19, 2009 | 10:37 AM
jewjew bean's Avatar
it doesn't even sound like it's your trans. it's probably just the throwout bearing
Old Feb 19, 2009 | 11:48 AM
skylinetph26's Avatar
Get it checked out by a mechanic before you go spending $$$$ on a new tranny that you might not need.
Old Feb 19, 2009 | 07:00 PM
jdm_xsi206's Avatar
well my cousin works at Bellevue honda and he told me it might be the tranny but not sure... i was also told it could be the throw out bearing. well ill got get it checked out.... thanks everyone
Old Feb 19, 2009 | 07:07 PM
Targa250R's Avatar
be professional
Sounds like a bad mainshaft bearing if it's making noise when you release the clutch pedal while sitting still in neutral.
It isn't the release bearing, otherwise it would make noise with the clutch pedal pushed in.
Old Feb 19, 2009 | 07:28 PM
keithg's Avatar
You can find lots of good used Accord and TSX trans on www.car-part.com
rsxworld
Feb 28, 2012 06:04 PM
nikko_SOHC
Northern California (Sales)
Apr 28, 2009 04:03 PM
eg6sittingon57cs
Jul 20, 2007 09:13 PM
02 Civic SI 865
Dec 16, 2006 06:44 AM
