Running too lean
Old Aug 9, 2002 | 11:35 AM
Litoman's Avatar
Default Running too lean
I have a problem with my idle. The car idles rough and at a steady rpm the engine light comes on. Code 43. I checked my O2 sensor and it seems to be ok. But the car wants to run lean. Too lean. I adjusted the fuel pressure, but it did't help a lot. The engine light still comes on. I'm not sure where to start. Please Help.
Old Aug 9, 2002 | 12:06 PM
Spade's Avatar
Default Re: Running too lean (Litoman)
43 Fuel supply system
You need to change your fuel filter and see if the code goes away.
Old Aug 9, 2002 | 02:10 PM
Litoman's Avatar
Default Re: Running too lean (Spade)
I have changed th fuel filter and the fuel pump.
Old Aug 9, 2002 | 02:13 PM
Spade's Avatar
Injectors?
Regulator?
Have you had the fuel system cleaned?
Old Aug 9, 2002 | 02:15 PM
Litoman's Avatar
I replaced my injectors. And put in an adjustible fuel regulator.
Old Aug 9, 2002 | 02:17 PM
Spade's Avatar
So are you sure you are getting a code 43......just bare with me.....
Did you clean the fuel rail when replacing the injectors?
Old Aug 9, 2002 | 02:18 PM
Litoman's Avatar
I'm sure of the code 43.
But I did't clean my fuel rail.
Old Aug 9, 2002 | 04:32 PM
Litoman's Avatar
I cleaned out my injector rail. It doesn't seem to make a change. Still the same thing.
Old Aug 9, 2002 | 06:19 PM
minime's Avatar
how did you check your o2 sensor?
Old Aug 9, 2002 | 09:56 PM
Litoman's Avatar
Default Re: Running too lean (minime)
I checked the O2 sensor. It seems to be working fine. I'm just not sure if the signal form the O2 sensor is getting to the ECU.
Old Aug 10, 2002 | 05:33 AM
Chiovnidca's Avatar
Old Aug 10, 2002 | 07:07 PM
Litoman's Avatar
Default Re: Running too lean (Chiovnidca)
With a multi meter. And someone with a new O2 sensor. Fined the signal wire. And check the voltage on each, and compare. The lower the leaner, the higher the richer. You want to be around .450. My O2 sensor gave the same readings. So I think it is safe to say my O2 is okay.
Old Aug 10, 2002 | 07:21 PM
Chiovnidca's Avatar
Did you check the high and low range of the O2? Does it measure over .8v at wide open throttle? Does it quickly go below .2v when the throttle is snapped shut? BTW, this assumes you have it warmed up to normal temperature.
Old Aug 11, 2002 | 08:44 AM
Litoman's Avatar
I did check the O2 with the car at normal temp. And I did check the range. And it did go from over .8v at wide open throttle. Then quickly go to below .2v, when closed throttle. Then if left to idle the voltage goes to 0v and slowly goes up to about .2v.
[Modified by Litoman, 9:44 AM 8/11/2002]
Old Aug 11, 2002 | 11:55 AM
Chiovnidca's Avatar
What is your fuel pressure? What happens when to your O2 voltage when you pull off the FPR vacumn line?
Old Aug 11, 2002 | 08:38 PM
Litoman's Avatar
I haven't looked what the O2 voltage is when I pull the FPR vac. But I mad a mistake in my last message. The voltage when throttle is closed is 0.02v not 0.2v.
Sorry...
[Modified by Litoman, 9:39 PM 8/11/2002]
Old Aug 11, 2002 | 09:21 PM
BoredNStroked's Avatar
What is your engine setup? How big are your injectors, fuel pump? How much fuel pressure do you have. What do your spark plugs look like?
Old Aug 11, 2002 | 09:23 PM
91f22's Avatar
possible vacuum leak? do you have anyway to wiew scan dataor 5 gas analyzer data. Possibly air bieng introduced into the engine after the throttle body could cause the car to run lean the fuel system will only compensate so far.is the vehicle running lean and setting a code or rich as a result of lean info from the o2 sensor?
Old Aug 11, 2002 | 09:53 PM
Litoman's Avatar
Default Re: Running too lean (BoredNStroked)
My engine is a D16y7 with a 92 DX intake manifold. And running all 92 emision.
The injectors are stock 99 CX, fuel pump is a Holly, fuel pressure is set to 47psi without vac. I had to raise the pressure or th car would stall. And the spark looks ok.
Old Aug 11, 2002 | 09:58 PM
Litoman's Avatar
Default Re: Running too lean (91f22)
I checked for vac. leaks. By spraying carb. cleaner around intake manifold. It did't seem to have a leak. But I could be wrong.
Old Aug 11, 2002 | 10:19 PM
Ideal's Avatar
time for a mechanic?
Old Aug 11, 2002 | 10:25 PM
tinkerbell's Avatar
how not?
do you have a FP gauge? what does it read? waht did you increase it to?
it should assist you.
in fact - it should make your car run richer no matter what!
t..
Old Aug 11, 2002 | 10:33 PM
Litoman's Avatar
Default Re: Running too lean (tinkerbell)
It only helped a little. The car doesn't stall at idle. I installed a pr gauge on top of my fuel filter. It originaly read 41psi without vac. I set it to 47psi without vac. I'm not sure how hi I can increase it to.
Old Aug 11, 2002 | 11:00 PM
tinkerbell's Avatar
sounds OK...
but your O2 sensor voltage sounds OK too,
what is the problem exactly?
the car runs rough at idle? and you got a code 43?
has this been cleared? did it come again?
how do you mean "too lean"?
this "I had to raise the pressure or th car would stall." is very weird!
now that you mention it - which injectors?
did your car come with Peak nad Hold or Saturated injectors...?????
t..
Old Aug 11, 2002 | 11:14 PM
Litoman's Avatar
The car is running rough idle, and code 43 comes up if driving at a steady speed or idle. The only way the car is running is by increasing the FP, and while driving pulsing the gas.
With the lean part. I was told by a mechanic that from the readings I was getting. The car was running lean. I know the higher the voltage, the richer and the lower the voltage, the leaner. But I am not 100% on what the car should run.
