What do change with timing belt?
Hey guys, I'm gonna need to do my tbelt / waterpump in a month, but I'm gonna order the parts now since I have to get something else and don't want to make two orders.
What exactly should I change along with the timing belt / waterpump? I want to do it properly and not cut corners. Should I change the PS / Alternator belts too? And any misc things like gaskets or tensioners or something? Is there like a part number for an OEM timing belt kit which would include everything that I should change?
Sorry if it's a common question but I searched and could not find anything...
Thanks.
Thanks.
I'm assuming a D-series engine?
There is no kit.
I recommend replacing:
- timing belt
- timing belt tensioner
- water pump
- coolant
- alternator belt
- A/C compressor belt
- power steering belt
. . . all at the same time.
You may need to replace the cam seal if you find it has been leaking, but that's uncommon for a D-series. Replace the valve cover gasket and spark plug tube O-rings as well if they're hardened or leaking.
There is no kit.
- timing belt
- water pump
- coolant
- alternator belt
professorman
Mar 27, 2009 02:02 PM
The-Kid
Feb 8, 2008 03:47 PM
