No power. any clues
Old Feb 16, 2009 | 09:05 AM
joesmoe23's Avatar
Default No power. any clues
hey fellas. 98 honda accord ex here. Just the other day I was driving along, nothing outta the ordinary, but when i got out of my car I noticed that my power locks didnt work. WIth a puzzled look on my mug, i also tried the power windows. The Driver side controls will roll down the driver side windows (front and rear) but neither of the passenger windows. The passenger side windows to roll down but only from there own window controls.....So there is power there, and then i tried the unlock on the door lock of the passenger door. Ya know when you unlock it with the key all the doors unlock, well not this time. These are the only two items that are acting wack.
Radio and everything else is working normally.
Any ideas on where to start before i go about tearing out my hair and also the interior of my car looking for grounds. I do have the wiring diagrams available for both circuits.
Thanks in advance. BTW this doesnt have remote keyless entry.
Old Feb 16, 2009 | 09:47 AM
brakedrum's Avatar
Default Re: No power. any clues
This might be a good starting point:http://groups.google.ca/group/rec.au...TF-8&q=99-022a
The symptoms are identical to yours. Sounds like an easy fix.
Old Feb 16, 2009 | 12:28 PM
joesmoe23's Avatar
brakedrum, I will give this a shot when i leave work today. I really hope it works, it does sound exactly the same.
The problem with this working though is that I canceled plans with the girl friend and invited some buddies over to drink beers and look at the car. Now if i fix it she will expect me to hang out with her. What a dilema.
Old Feb 16, 2009 | 12:51 PM
brakedrum's Avatar
Well, according to that TSB, the quirk in your car is that a multiplex control unit falls asleep and can be awakened by turning the key while another part is turned on. Trust me, old girlfriends work the same.
Old Feb 16, 2009 | 01:48 PM
joesmoe23's Avatar
dooooooooooooooood, that **** worked!!!! Woohoo. I dont have to pull the passenger seat out and check the ground, i dont have to trace wires. Woohooo....Brakedrum, dont take this the wrong way, but i might just scream out your name the next time i have sex with my girl. Fortunetly that wont be tonite, I decided not to tell her i fixed it already.
Time to drink some beers and do some dumb ****.
Old Feb 16, 2009 | 03:20 PM
brakedrum's Avatar
Naah, don't be yelling car parts. Then she'll know the Honda is your first love. Glad the fix worked. it's good when it doesn't turn into weeks of testing and diagnosing and then a parts chase. It appears Honda came up with that quirky little fix to avoid recalling thousands and thousands of those multiplexors.
Old Sep 17, 2010 | 01:57 PM
josee's Avatar
HEY BRAKEDRUM HOW ARE YOU BUDDY?. QUICK QUESTION FOR YOU. I HAVE A 1998 HONDA ACCORD LX, I AM HAVING A PROBLEM WITH MY POWER WINDOWS AND POWER LOCKS. ALL OF A SUDDEN MY POWER LOCKS AND PASSENGER RIGHT WINDOW FRONT AND REAR STOPPED WORKING FROM THE MASTER SWITCH BUT THEY WORK FROM THE PASSENGER SWITCH I READ THAT SOMEONE HAD THE SAME PROBLEM AND YOU HELPED HIM OUT BUT I TRIED TO DO THE SAME BUT MAYBE I DID NOT DO IT RIGHT CAN YOU EXPLAIN TO ME IN MORE DETAILS PLEASE I REALLY NEED YOUR HELP REAL BAD. I WILL REALLY APPRECIATE THIS BUDDY THANKS IN ADVANCE.
Old Sep 17, 2010 | 07:14 PM
brakedrum's Avatar
I only read this forum perhaps once a month but happened to log into it tonight. haha. Basically the Honda Technical Service Bulletin (TSB) says the following:
Repair Procedure:
1. turn the ignition switch off
2. turn the wiper intermittent time ring to the middle position.
3. turn the ignition switch to on.
4. check the operation of all the power windows from the master
power window swtch and the power door locks.
I'll not my gut feelings.
1-In executing the procedure it's important that the switch be completely off before doing anything.
2-The intermittent wiper ring (formerly called a wiper delay switch) MUST be set to the middle position or hash mark on the ring.
3-Turn the switch to the pre-ignition point, but DO NOT start the car. Pre-ignition basically means the "all systems go" point -- fuel pump will prime, etc.
4-Try the window and lock controls while the switch is in that position. If they work, your multiplexor is awake and you're done.
Old Sep 18, 2010 | 11:55 AM
josee's Avatar
men!!!!!!! u'r my hero brother'... i really appreciate it thanks a lot it worked out perfect.
Old Oct 2, 2011 | 01:34 PM
tulizan's Avatar
this site rocks just fix my son's 1998 accord power window
Old Oct 2, 2011 | 03:23 PM
renk's Avatar
anyone knows a solution if this doesn't work ...... I could now control my passenger side window but the locks still don't work
dustdevil06
Honda Civic (2006 - 2015)
May 4, 2013 08:16 AM
jermo
Sep 25, 2012 09:27 PM
Tonyl507
Audio / Security / Video
May 15, 2011 07:07 AM
civiceg94
Jul 10, 2007 12:27 PM
phantomx_teggy
Sep 9, 2004 10:44 PM
