Having problems passing smog...
Old Feb 16, 2009 | 01:55 AM
Cloneufc's Avatar
Default Having problems passing smog...
Ok I have an EP3 and it has about 160k on it. It was throwing code p420.I had a bad CAt so I bought a used OEM one. When I put the used cat on it threw p420 again so I reset the ecu again. It did this twice then finally went away. After about 20 miles of driving. I parked it and noticed the cel light flashes 5 times with key on engine off. When I looked it up it said it was probally a bad map sensor. Well I reset the ecu and then drive another 20 miles and the cel came back on. Well when I plug in my scanner to check the codes there are no codes present, just the 5 cel blinks with key on engine off. Does that mean I might have a bad pcm?
Old Feb 17, 2009 | 05:45 AM
mustclime's Avatar
Default Re: Having problems passing smog...
When was the last time you changed you plugs? I would run a couple tank fulls of super( for the the ethenhal) and may be run some V-Max fuel treatment through there.
Old Feb 17, 2009 | 05:47 AM
josh's ep3's Avatar
Function > Form
Or some lucas oil feul system cleaner.
Old Feb 17, 2009 | 11:30 AM
mustclime's Avatar
I like the z-max stuff, It really works.....
Old Feb 17, 2009 | 11:40 AM
josh's ep3's Avatar
Function > Form
I think I'll try that next. I usually would start using a bottle of the Lucas every other oil change and it lasts for a 100 gallons of usage. Is the Z-Max available at autozone and places like that?
Old Feb 17, 2009 | 11:56 AM
mustclime's Avatar
Yea, its like 20 bucks a bottle.....but it pretty much cleans off the backs of your valves in one tank full.....good stuff.
Old Feb 17, 2009 | 12:27 PM
josh's ep3's Avatar
Function > Form
Nice, yeah I'll give it a try lol, where's the OP?
Old Feb 19, 2009 | 02:25 AM
Cloneufc's Avatar
I got off the phone with the dealer today and they told me that the ecu is in learning mode. The ecu is learning map load and that if I take it on a couple hills and floor it for 2 seconds here and there that it will go away. Im posting this for others if they have this problem. Thanks though.
Old Feb 19, 2009 | 03:31 AM
Targa250R's Avatar
be professional
It just means that the ECU readiness monitors aren't set to "complete" yet. You have to put the car through a couple of drive cycles after you reset the ECU. Once the "not ready" monitors are all set to "complete," then it will stop.
Old Feb 19, 2009 | 03:23 PM
Targa250R's Avatar
be professional
You know how I can tell you're only 19?
Old Feb 20, 2009 | 05:08 AM
josh's ep3's Avatar
Function > Form
Because my profile says so...
Old Feb 20, 2009 | 06:00 AM
DaveSi677's Avatar
haha lol
Old Feb 20, 2009 | 10:22 AM
stickyicky's Avatar
What made you think it might be the MAP sensor?
Did it throw any other codes other than the p420?
When you last checked for codes with the scanner did you look at the freeze data?
rjmq06
Oct 10, 2010 09:25 PM
lucky6
12
Jul 17, 2009 08:58 PM
b20vtech
19
Feb 6, 2009 08:21 AM
Gronked
Oct 29, 2007 06:12 PM
Nocide_Eluded
May 24, 2004 06:12 PM
