plz need help on h22a 95 >>>
Old Feb 15, 2009 | 09:07 PM
h22a95's Avatar
Default plz need help on h22a 95 >>>
I bought a 93 hatchback and took it in to have an engine swap. I put a h22a 95 with chrome ecu. After the engine swap I took it to another garage to have cam shafts installed, blox type b. They also installed springs, retainers and cam gears. Before i took my car to the garage it had 190 whp, now with the new camshafts and etc. it is 193. My car used to hit at 3000 vtech and now its hitting at 5000 so I am loosing horsepower in the midrange. So what has caused this problem? Is it from the ecu tunning or do I need to get pistons?
All the work I'm doing is all motor, not involving turbo.
thanks.
Old Feb 15, 2009 | 09:28 PM
pprowler6's Avatar
Default Re: plz need help on h22a 95 >>>
i think the least of your worries should be you car... try to focus more on making complete thoughts and sentences then we should be able to help you more....
Old Feb 15, 2009 | 09:46 PM
h22a95's Avatar
Okay sorry,
thanks.
Old Feb 15, 2009 | 10:12 PM
streetracer6rpt's Avatar
u put cams in and u havent retuned??
Old Feb 15, 2009 | 10:14 PM
h22a95's Avatar
need help in here..
Old Feb 16, 2009 | 01:55 AM
h22a95's Avatar
i did tune it again.. and i think he didnt tune it good ..thats why im asking you guys cuz the guy who tuned my car he said u have to but big pistons ... thats why im asking u guys to help me out..
Old Feb 16, 2009 | 09:55 AM
Pman92's Avatar
Bigger pistons would help but it sounds like he's not correct on the new cam durations. Is this the guy who tuned it first to 190whp for u. Is it the same dyno as before. What ecu/ program are u using. Is vtec kicking in. need a little more info, but im no expert.
Old Feb 16, 2009 | 10:33 AM
iwanttokillgod's Avatar
h22a95 have you ever looked at your motor learn how to spell vtec there is no h
Old Feb 16, 2009 | 11:12 AM
Mervin's Avatar
did you get 193 hp on the same dyno as the 190 hp reading?
readings differ between dynos...........
that said, 190 seems highish stock..........
Old Feb 16, 2009 | 12:18 PM
h22a95's Avatar
i did it at the same dyno and they but the cams for me.. it was hiting at 3000 and now after the cams its hiting at 5000 ..
i have a chrome ecu..
Old Feb 16, 2009 | 12:22 PM
pprowler6's Avatar
all i know is if vtec was kicking in at 3000 rpms thats far to low. obviosuly when he tuned it he changed it to 5000 rpms becasue thats what is ideal for your engine to make a smooth power band. but i really dont know much
Old Feb 16, 2009 | 03:40 PM
h22a95's Avatar
k thanks..
any more??
Old Feb 16, 2009 | 04:13 PM
PremiumPrelude's Avatar
Honestly kid... You need to really think about things before you actually do them. 190 on a stock motor is a little sketchy. Why in the world would you have vtec hitting at 3000rpm?? Have your car retuned and redynoed.
Old Feb 16, 2009 | 09:44 PM
h22a95's Avatar
yeah i did and now it hits at 5000 and made 193whp but drops 20whp in midrange..
Old Feb 16, 2009 | 09:47 PM
slomofo's Avatar
GDD Member
VTEC engagement at 3k is a little too soon. I think the dyno numbers were skewed the first time around because I highly doubt a stock H22 would pull 190whp. It also sounds like you need to find yourself a better tuner.
Old Feb 17, 2009 | 12:45 AM
h22a95's Avatar
thanks slomofo..
but when i put bloxs tybe b cames its just gave me 3whp whats wrong with that?
ruzzo21
Sep 24, 2012 07:49 PM
darkvaliance
Feb 23, 2007 06:00 PM
