Blox Cams?
Old Feb 15, 2009 | 09:05 PM
Benefitx's Avatar
Default Blox Cams?
anyone use these before? 266 intake and 266 exhaust...are these direct drop in for b18c5??
http://cgi.ebay.com/ebaymotors/Blox-...Q5fAccessories
Old Feb 15, 2009 | 10:57 PM
redGSRguy's Avatar
Default Re: Blox Cams?
I used the BLOX "Jun 3" Type C cams in my gsr build in my sig. The cams will fit in a b-series no problem, do think about upgrading the valvetrain.
Old Feb 16, 2009 | 03:45 AM
Circuit Star-29's Avatar
Agreed. I use Type-As in a stock B16B motor. Great cam w/ good dynamic compression. Will be going to type-Cs soon when I finish my other block.
Type-B/C's should atleast have a valve spring upgrade... imo cause of the increased ramp angle and assumed increase in RPM to get more potential from the cam compared to stock ITR or CTR cams...
Good cams, IMO.
Old Feb 16, 2009 | 11:05 AM
nineD3civ's Avatar
Good cams, IMO.
do you need to upgrade the ctr valve springs with Type-B's? i have a b16b also and want to purchase stage 2 cams
Old Feb 17, 2009 | 12:01 AM
With the B's i would def go to a stronger spring and lighter/stronger retainer. You should go to a two layer headgasket. The B's will be a bit better with more compression.
Old Feb 20, 2009 | 04:13 PM
4o8itr's Avatar
I'm running Blox B's and upgraded valvesprings and retainers from Supertech and it works great
OrangeTeggy
Jan 6, 2010 11:42 PM
Cain Marko
10
Aug 27, 2009 04:31 AM
cdfran
May 19, 2008 07:13 AM
thehatchninja
Jun 10, 2005 11:37 AM
12345
Feb 11, 2003 10:42 PM
