Suspension & Brakes Theory, alignment, spring rates....
EG hatch - front brake options
Old Feb 15, 2009 | 07:28 PM
EFbomb's Avatar
Default EG hatch - front brake options
I've read brakexpert's threads on options for brake upgrades. Maybe i missed something, but i didnt see much info on the EG chassis, just the EK(96-00)
My hatch is a cx with stock dinky front rotors. I have acquired the 1" non ABS Master Cyl, 4040 valve and rear integra disc installed, and i'm looking to find some OEM/budget solution for front upgrade.
I saw some info on running Corrado G60 11" rotors with S2000 calipers, i need to know if that bolts on to the cx knuckle like i have or if i need to upgrade to different knuckles.
I've sourced some s2k calipers for $130 shipped for the pair, and i can pickup OE replacement corrado rotors for about $40 per rotor.
Also what size wheel will clear that brake setup
thanks for any info
Old Feb 17, 2009 | 05:32 AM
Lasky's Avatar
Default Re: EG hatch - front brake options
most likely those wont fit on the cx knuckles.. you need the bigger EX ones and if im not mistaken any 94-01 integra ones will do the same job. another cheap way to improve stopping would be to get the 2000+ accord V6 calipers as there pads have a much larger surface area compared to the stock EX ones. thats one of brakeexperts cheap upgrades.
Old Feb 17, 2009 | 07:14 AM
EFbomb's Avatar
i figured i'd need some different knuckles.
Old Feb 17, 2009 | 01:09 PM
jr_deleon's Avatar
Here is one of brakeexpert's old threads. Your Cx knuckle is what you need. If you get an Ex/Dc knuckle, that 11 inch rotor will be too small (take it from me, i have the s2000 11.8in upgrade on my eg). The setup below is the Corrado rotors, modified (milled) s2k brackets with the calipers on the 9.5" knickle (what your CX has)
So there you go.
DX/S2000 brake upgrade
This is a for a front brake setup for all 88-00 Civics with the stock 9.5" brakes. Our steering knuckles have the tabs pulled in and don't work with a lot of other setups. However, now there is a great, lightweight option without even needing to change steering knuckles! This setup comes with S2000 calipers, modified brackets, pads, new rotors, and centering rings. It is a bolt on for all 88-00 Civics and all CRXs that have the 9.5" brakes, such as all DX, CX and LX models, CRX HF and Si, 92-93 Civic Si without ABS, and any 88-00 Civic or 90-01 Integra with Civic DX steering knuckles.
This setup uses the lightweight S2000 calipers and 11" rotors and clears 15" wheels (and some 14s such as the RacingHart CPF, Volk TE-37 and TE28, Kosei K1s, and others but I don't know which.)
Old Feb 17, 2009 | 05:43 PM
EFbomb's Avatar
Originally Posted by jr_deleon
So there you go.
YOU ARE THE MAN!!!!!
thanks alot! Nice to see good guys helping around HT!
Old Feb 18, 2009 | 08:24 AM
jr_deleon's Avatar
No problem. Thats how it should be on Honda-Tech. unfortunately, good help without sarcasm and attitudes are becoming harder to find here.
If there are any specifics that you need to help further, post it up and we'll do what we can!
Old Mar 8, 2015 | 09:18 AM
RaelynLabs's Avatar
anyone have a picture of the milled bracket for the s2k corrado setup? getting ready to build it and want to be sure before milling.
Old Mar 10, 2015 | 01:09 AM
speedjunkie_g35's Avatar
From: Pensacola, FL and every Court House in Louisiana
Itr calipers with mini cooper rotors on a ex knuckle bolts right up. Mounting bracket doesn't need to be shaved. Was a huge improvement over my vx/cx brakes.
Old Mar 10, 2015 | 07:38 AM
94CivicHatchGSR's Avatar
I'm interrested in this upgrade. Been reading a lot on it. I've read that the mini cooper rotors aren't hubcentric to the spindles on the hondas? Does your rotor fit perfectly or is there some wobbling? What mounting bracket would you use in this case? ITR or civic cx?
Old Mar 10, 2015 | 04:21 PM
The itr bracket I believe 23t... the mini cooper rotor isn't hubcentric but I have never had issues with it centering up once I put the wheel on and tighten lug nuts. I track my hatch on a regular basis. And if running a 15" wheel, you must have a 14" Inner diameter barrel.
eHMxhACk
Suspension & Brakes
Mar 31, 2016 09:32 AM
Civi_eg3
Sep 24, 2015 05:54 AM
eg6 type-R
Suspension & Brakes
Aug 30, 2012 10:07 PM
crfr230
Feb 19, 2008 03:14 PM
k-series
16
Jan 13, 2005 08:08 AM
