What to do about my trans????
Old Feb 15, 2009 | 06:48 PM
Trowwa-EJ6's Avatar
New User
Icon2 What to do about my trans????
Hello im in need of some advice i have a 98 civic dx and my second gear has gone out and third is on its way. I think im going to pull the trans and get a re build but i wanted a second opinion from someone who knows more : )
Old Feb 15, 2009 | 06:51 PM
CRAZYHONDA's Avatar
Default Re: What to do about my trans????
take out old one and buy a good used one
Old Feb 15, 2009 | 07:01 PM
ALLxMOTOR EG's Avatar
Vietnamese!
Buy another 1 if you come on a good deal,if not then rebuild the old.
Old Feb 15, 2009 | 07:17 PM
ElusiveEK's Avatar
New User
It'll cost around the same to rebuild it, just buy new one.
Old Feb 15, 2009 | 07:31 PM
joelmatt89's Avatar
what do you mean by going out, usually when people think there gears are going out it is actually just their syncros. What are some symptoms explain to me what happens when you try to shift gears. If you have an extra car you can drive my advice to you is open your transmission up before you do anything than you will be able to see what is wrong, and if it is just your syncros rebuild it cause that would be really cheap. If you have bad gears than yeah a used tranny may save you time and money
Old Feb 15, 2009 | 09:28 PM
Trowwa-EJ6's Avatar
New User
your right third is for sure the syncros but im not sure about second if i try real hard and use my skillz (jk) i can make the gear 80% of the time but i hear stuff moving around sometimes when i start out in frist and sometimes in second. If i do buy used do you know of any good places i can check out? ty all very much for your help so far i am greatfull : )
Old Feb 15, 2009 | 09:48 PM
andoxviii's Avatar
If you lack the skills to repair the transmission yourself, it will probably be cheaper to buy a used transmission from your local junkyard or Japanese importer. If you can repair it yourself, there is no reason not to! It will be a good experience and cheaper.
Old Feb 15, 2009 | 10:00 PM
92 hatchback's Avatar
yeah i would just rebuild my trans
Old Feb 16, 2009 | 12:17 AM
trustdestruction's Avatar
Not to mention that the rebuilt one will be like a BRAND NEW transmission as opposed to a used one.
circlehonda
Transmission & Drivetrain
Oct 18, 2015 02:43 PM
shutta
Jul 12, 2006 02:02 PM
tunedek
Jun 16, 2004 03:14 PM
hondaciv15
May 28, 2004 10:38 PM
redexchris
Jan 31, 2003 08:01 AM
