Wheel balancing and alignment
Old Feb 15, 2009 | 04:47 PM
sobey's Avatar
Default Wheel balancing and alignment
Hi guys,
Just got a set of rims (used for a couple of years). Can I just put these on, or is it a good idea to get them balanced. If so how often should tires be balanced?
Same with alignment. When should I go for an alignment? In your experience, do Accords need to be aligned frequently? Had the car for 10+ years and no alignment. Wheel wear looks normal (they are rotated once a year).
THanks
Old Feb 15, 2009 | 04:51 PM
tamadrummer1120's Avatar
Default Re: Wheel balancing and alignment
Well it is best to just pay the money and get them balanced, but if they need new tires somewhat soon, go ahead and just get them done and then obviously they will balance the wheels once the new tires are put on. For the alignment, you answered your own question. If tire wear is normal and the tries look straight up and down and side to side (toe and camber) then you should be fine. Not like you are lowering it or anything.
Old Feb 15, 2009 | 04:53 PM
sleepy96's Avatar
You should get them balanced. Are you going to a different sized rim? When you get the tires mounted, you should have them balanced.
You should only have to get the tires balanced when you put new ones on. I've never seen a recommended interval(it might possibly be 100,000 miles, but i can't remember). If you start to notice wear, or shaking, then you should get them balanced. If that doesn't fix it, get the alignment checked. But generally it's only when you get tires mounted that you have to worry about the balancing.
Old Feb 15, 2009 | 05:08 PM
TheMuffinMan's Avatar
He knows where you live!
Balance and alignment and sleep good at night.
Certainly doesn't hurt to have it done every so often
Old Feb 16, 2009 | 06:03 AM
sobey's Avatar
Thanks for the input guys. Will definitely have them balanced for peace of mind.
born2lose
Suspension & Brakes
18
Aug 13, 2014 10:04 PM
CallMeKing
Apr 20, 2012 10:51 AM
94CDMeg
Sep 4, 2008 08:49 PM
Honda.F1
Honda Civic (2001 - 2005)
Oct 18, 2006 04:35 PM
Type R 01
Oct 1, 2002 01:21 PM
