h22 into 99 si distributor questions
Sup guys, Im in the process (half way actually) of doing my OBD1 h22a swap into my 99 si. Now heres the scenario. Im using 99 si harness and a chipped p30 ecu and 440cc saturated injectors . My distributor came with 2 plugs and looks like this
Now my original b16a2 came with a fat one plug
Does anyone know how I could make this work or have some kind of a pinout for THIS setup? thank you!
also someone told me that if I were to run a p13 ecu, I have to wire the distributor DIFFERENTLY than if I were to run with a chipped p30 (of course using my si harness). Is this true?
THANK YOU ALL
THANK YOU ALL
No one seems to know? I really really hope someone could help me with this. the motor is almost completely in the car and HOPING if someone could shine some lights for me on my questions. Thank you so very much.
THANK YOU ALL
Clip the connector off the prelude harness, and just color. The colors should be the same.
as far as running the dizzy different between the two ECU's, no. you can switch back and forth between the two ecus if you like. You will just throw a butt load of codes with the p13 ecu... good luck...
Yeh, I did the same, just color match it. I used the 0bd1 h22 dist and just chopped off the plug and use the Si plugs. All color matched. Well, it should right?
