air to fuel gauge question
Old Feb 15, 2009 | 10:19 AM
j0keefe21's Avatar
Default air to fuel gauge question
i was looking into getting an air to fuel gauge and it says it works right off the 02 sensor... my question is will it work off my stock sensor or will i need to get a wide band sensor?
Old Feb 15, 2009 | 10:25 AM
BOOSTED RIVAL's Avatar
Default Re: air to fuel gauge question
What brand is it? if it autometer it will work of your stock O2.
Old Feb 15, 2009 | 10:31 AM
j0keefe21's Avatar
i believe sunpro.. autometer would be cheaper then if i dont need a new o2 right?
Old Feb 15, 2009 | 03:01 PM
turboedsohc89's Avatar
Depends on what your doing wit it are you going to be tuning a turbo car or just want it for looks.If you just go buy some autometer on or sunpro w/e there about as usefull as the light bar on the front of KnightRider which is pretty much for show. Depends on how much you wanna spend in my opinion I would get an AEMugo wideband. The only problem wit using the stock o2 is that youd only be getting an narrowband signal doesnt do much. long story short (wideband)
Old Feb 15, 2009 | 03:55 PM
pacificrim's Avatar
afr narrowband gauges wire connect to stock o2 sensor wire.not requiring wb.
Old Feb 16, 2009 | 11:42 PM
ixoiiiiviviiivi's Avatar
Where would the purple wire go into a p2t? Should I use Primary or Secondary O2?
Would using a cat affect connecting into Secondary O2?
Here's the P2T pin readout options...
[A8 - SO2S HTC]
[A23 - SHO2S]
[C1 - PO2S HTC]
[C16 - PHO2S]
Should the 12v ig (red) and ground (black) go into the ECU as well or tap into another source? I already have a VAFC hooked up to [B1 - IGP1] and [B20 - LG1]
Thanks
Old Feb 17, 2009 | 01:32 PM
j0keefe21's Avatar
i read narrow bands have 1 wire... mine has atleast 3 or 4... is that wide band then?
Old Feb 17, 2009 | 04:29 PM
Look I wouldnt be taping off the ecu anywhere or the o2 just go wit a true wideband trust me its way better
Old Feb 17, 2009 | 04:32 PM
Honestly, what are you trying to do wit the A/F gauge? thats the question at hand once we know what you want/need one for we can help you better
Old Feb 17, 2009 | 08:46 PM
boostwhoreeg6's Avatar
New User
the purple wire goes to the signal wire on the o2 sensor which is the white wire. you will use the primary o2 sensor, that is the sensor that reads your a/f ratio. the secondary o2 is basically to tell your ecu if your catalytic converter is working correctly. never connect anything directly to the ecu, your 12v source wire should be connected to a keyed power source and is fused. jokeefe the reason your o2 sensor has more wires is because it is a heated sensor which doesnt make it wideband. but basically like what turboedsohc was saying its a pointless tool and only good for show purposes.
Old Feb 17, 2009 | 09:13 PM
jgraham0326's Avatar
I would have to agree with Turboedsohc on everything he has stated. if your just going to buy one of those autozone AFR gauges you would have better luck drawing on cardboard with crayons and mounting that up. If your doing something in which it requires you to read your AFR's you need a true wideband. I would suggest plx devices that are cost effective and come highly recommended from HONDATA plus it is what I own and so far it has been great.
Old Feb 18, 2009 | 12:41 AM
hoffmanb16's Avatar
i have the autometer air to fuel gauge and it is pointless, it just bounces around senselessly.... It knows when your on the throttle and when your off it.... thats about it. It came with my car.... it's kinda fun but wideband is what you need if you want some real accuracy.
Old Feb 18, 2009 | 10:27 AM
j0keefe21's Avatar
im swapping out my stock cam for the A6 one for a 91 crx si. and bumping the compression up a little with a thinner head gasket. and your basic bolt ons.
Scud
Dec 28, 2006 09:01 AM
KStuned
Oct 6, 2004 11:39 AM
CalvitoSol
Jul 6, 2002 07:00 PM
