Dash lights & Tail lights Don't work!! PLEASE HELP!!!!!!!
I'm not sure if this is the right forum .. move if needed .. Thanks!
Ok I've got a 95 Civic Hatchback and when I went to start it the other day I noticed that my dash lights were out so I checked the fuse and it was blown so I replaced the fuse and it was fine .. until the next morning then the same problem only now the fuse blows every time I turn on the headlight switch .. I've used a test light and the test light comes on as soon as i turn on the headlight switch so I'm pretty sure there's a short somewhere .. but I still haven't found it.
As far as I can tell the fuse is used for .. the dashlights, taillights, license lamp and the combination switch (I think that's the headlight switch??) .. I've tried disconnecting the taillights and the license lights from the harness and tugging on the wire harness and still no luck .. I was wondering if anyone could tell me how to check if the headlight switch itself was bad and causing the fuse to blow or if anyone else has had this sort of problem .. sorry if this is a repost .. Thanks
oh .. sry .. ok I'll try that tomorrow .. this may sound dumb but how do I use the multimeter to check it .. I see what terminals to check but do I put one probe on each terminal (Red on D terminal and black on the E) or do I touch them one at a time .. sry I'm not that good with electronics but i'll try .. Thanks again
you touch one to each terminal at the same time, it doesn't matter which is red or black. do it the way the diagram says. the switch must be in the position of the function you are testing the switch for.
I found it .. sort of .. i disconnected all the connectors that go to that fuse and the test light went out .. It's in the hatch area .. I've removed all the bulbs in the tail lights and it's fine until I put a bulb back in then the test light come on .. one of the sockets is really rusted out .. could this be causing the short? Thanks!
since you removed it though and it fixed it, the first thing i'd try is replacing the socket. that should probably fix your problem.
mike11
18
Jul 21, 2011 07:22 PM
TheCivicMafia
14
May 15, 2009 03:52 AM
20_sec.hatch
Oct 22, 2007 03:31 PM
