gsr cam caps??
Old Feb 15, 2009 | 09:44 AM
92bseries's Avatar
Default gsr cam caps??
i have no cam caps for my gsr head. it i bought caps from a different gsr head and had them lined honed, would i be able to use them in my current gsr head? or is the gsr head i have now garbage? help is appreciated thanks
Old Feb 15, 2009 | 09:48 AM
EnjoyTheRideDC2's Avatar
Default Re: gsr cam caps??
As long as you get the cam caps line honed with the head, you can make use of the head.
Old Feb 15, 2009 | 09:49 AM
92bseries's Avatar
****, thank you very much sir for the quick response
Old Feb 15, 2009 | 02:03 PM
NJIN BUILDR's Avatar
The caps have to be matched to the head they are going on.Aline boring or honing does that.The caps would need to be bored or honed every time they are used on a different head.
Old Feb 15, 2009 | 03:45 PM
92bseries's Avatar
has anyone on the boards done this?? so i know what to expect if any of them have had any problems. yes i will have them lined bored, head milled, honed, the head cleaned all that good stuff. id just like to hear from some one who has done this like i said to know what to expect
Old Feb 15, 2009 | 09:19 PM
slomofo's Avatar
GDD Member
The cams were stolen from my B18C1 and I bought some random B17 caps to fit it. I sent the head to a machine shop with the new caps to be line honed and never had a problem.
Old Feb 16, 2009 | 11:33 PM
I picked up a head without caps for cheap and had to find a set of caps and rockers from another gsr head. As long as you choose a good machine shop, you should have no problems. They'll check out the head to make sure its useable and all the good stuff. Also, I'm not sure what you consider milling the head, but resurfacing it would be more suitable. Dont remove too much material unless you've already thought out your complete setup.
There's nothing to really "expect" when you get the cam caps line honed with the head. Its just machine work done to ensure the cam journals are fit to the head and not unbalanced or out of round..
Old Feb 17, 2009 | 12:49 AM
92bseries's Avatar
what about the cap rails? those will be fine just as long as the caps are properly line honed?
Old Feb 17, 2009 | 06:05 PM
POORMANT's Avatar
you can have this done but when you line bore a head your taking away when there is no tolerance this is not like a block where you can take away and measure and add bearings to make it correct if you have to line bore a head ever your changing whats all ready correct and you cant add to it to make it the way it was when bored and you may not have any problems now but you will and if your like me im not spending 8000$ on a motor and have to worrie about this down the road plus for what this guy needs for this head to make it complete is going to cost about twice what they go for
ps: i know him
Old Mar 1, 2009 | 06:40 PM
Christopherian1982's Avatar
Do they also need to be bored and honed if the camshaft are different?
Old Mar 2, 2009 | 11:55 AM
No, they dont.
Old Feb 10, 2010 | 08:07 PM
ohsnapzafingcu's Avatar
I serve phở for my babies
back from the dead:
i have a GSR head that i broke a valve on and messed it up... can i transfer everything from it to my bare type r head?
I can get the cam caps line honed, what about all the rockers, shafts and crap for vtec?
will i be fine transferring parts from a complete head to a completely bare one?
Old Feb 11, 2010 | 05:27 AM
zedron's Avatar
Originally Posted by ohsnapzafingcu
back from the dead:
Yes everything will transfer over. Just get the caps line honed to make sure they match the R
Old Mar 22, 2010 | 04:54 PM
Sprint2007's Avatar
back from the dead yet again! Sorry for the thread jack fellas but ur questions were already answered lol is line bore and line hone the same thing? I have a similar situation, I got a head but came without caps, so bought some caps. The shop here says they can line bore them but not line hone? I'm lost lol..
Old Mar 23, 2010 | 04:20 AM
Dogginator's Avatar
Daisy... Daisy...
It can be done, but do not remove much material since there are no cam journal bearings. A Helm manual should have the specs for the bore diameters. A hone would be preferred.
insaneconceptz
May 29, 2010 05:10 PM
diesel1245
Mar 25, 2007 06:48 PM
KMk51188
Dec 17, 2006 12:35 AM
frogscivic
Feb 4, 2003 01:13 AM
frogscivic
Jan 31, 2003 12:57 AM
