a6/y8 mini me, larger timing belt tensioner?
Old Feb 15, 2009 | 05:00 AM
johnwohl's Avatar
Default a6/y8 mini me, larger timing belt tensioner?
Hi! I'm having trouble with the timing belt setup for my d16a6/y8 mini me swap. I got a belt with the right amount of teeth, but even with the stock a6 tensioner manually set at full tight, the belt still has a bit more slack than i feel comfortable with. What i'd like to know is if there is a larger tensioner that I could install on the a6 block with little trouble that would be able to take up a bit more slack?
tl;dr : is there a larger timing belt tensioner that would go on a d16a6 block?
corey198807
Oct 13, 2010 12:27 PM
one-cam
Aug 15, 2008 08:11 PM
ef-hatchcrap
Apr 18, 2008 03:43 PM
StupidSlowRSX
Feb 15, 2008 03:00 AM
lazynok
Jul 30, 2004 10:11 PM
