idle problem , please help..
Old Feb 15, 2009 | 03:58 AM
pacificrim's Avatar
Icon2 idle problem , please help..
Hi everyone ,
i have a problem for my idle , this is the video my problem ,
http://www.youtube.com/watch?v=JGAJ7w2OJrg
http://www.youtube.com/watch?v=W_F_i...eature=related
Whats that ? :S
This car isnt me , and i have no cel light , but same problem.
thanx everyone
Old Feb 15, 2009 | 04:05 AM
random chaos 85's Avatar
Default Re: idle problem , please help..
thats a bad iac valve
Old Feb 15, 2009 | 04:14 AM
pacificrim's Avatar
but my car idle is good when i didnt hit the gas ?
Old Feb 15, 2009 | 04:28 AM
pacificrim's Avatar
could be a vacuum leak ???
Old Feb 15, 2009 | 07:04 AM
robbys89's Avatar
could be a vaccum leak alri. just tighting up all bolts around the intake mani and top up on coolent. thats the advise i got before when i had that problem. but when i renewed the fuel filter it was ok, turns out it was a little cloged and wasent feeding enuf fuel
Old Feb 15, 2009 | 07:20 AM
joshkx's Avatar
ecu? mines hunts, so when i switch my ecu its didnt idle at all....
Old Feb 15, 2009 | 08:34 AM
bossm's Avatar
could be a vacuum leak check the hoses around the im and also the pressure regultor hose too if not then its the iac
Old Feb 15, 2009 | 08:38 AM
Pothole987's Avatar
I would say the Throttle body gasket may be leaking. (or its loose) since you don't have a CEL
Old Feb 15, 2009 | 08:49 AM
tx_ej8_49's Avatar
Looks like you DO have a CEL. Start there, the work your way down the list. Vac leak, IAC, ECU, TPS, etc etc.
Old Feb 15, 2009 | 08:56 AM
Pothole987's Avatar
The OP SAYS IT RIGHT HERE.
followthadollar
Apr 20, 2010 06:23 PM
crxfreak1117
Sep 8, 2007 07:05 PM
b16a4
22
Jun 1, 2007 02:37 AM
silverboost
Sep 26, 2005 10:21 AM
Jeff_B
Feb 7, 2005 06:51 PM
