water pump leaking
no the heater wouldn't fail...but scince it takes it heat from the coolant well then you might c a drop in the heat from inside the car...depending on how bad the leak is...either way get that water pump fixed befor u overheat the engine and start looking for swaps...
RedRyda
Jun 16, 2004 04:41 PM
