o2 placement question on the downpipe
was wondering if it would make a diff if i put behind the motor instead of the front??? im runing a aem wideband as well that will be back there to
why would you not listen to the aem instructions on their website?
http://www.aempower.com/images/produ...%2030-4100.pdf
Stock location should be fine. I would put the wideband first then stock o2. This is why I like plx. 2 outputs so you can delete the factory o2 and still run closed loop.
i am runing both stock and my aem. just wanting to know if its ok to have them behind the motor instead of the stock one up front.
opps, im too use to the b-series having it past the oil pan from the factory. but yes you are fine. i think 24" from the turbine is the suggested distance anyways.
SpeedMonkeyRacing
May 12, 2003 12:41 PM
